I found a set of aluminum 2.2 wheels.. they bolt up like stock.. That might be the best for me.. I do like how these wheel fit size wise with the Blazer body
Body mounts are done.. stock rear works perfectly, I 3D printed the front mount, not sure if I need side mounts or not. I assembled most of the truck, but need to take it apart for paint. Hood is a bit tight so I need to clearance it as the paint will make it a bit thicker. Also anything needing glue is not installed. Suggestions on glue to use..
i also have on picture of my 4wd converted Blackfoot Extreme with a Clod Body. The clod is definitely NOT 1/10th scale. I would like to find some sort of push/bull bar for the Blazer. I might need to design and print it..
Well this one is not strong enough. I did finish it to see if I like it. It needs some work and would need to be printed out of ABS..  the original design had the push bar out too far
here it is complete for a first prototype
  • 4 weeks later...
No updates.. life and work have gotten in the way, however it is starting to warm up here, soo I am hoping to pick out some paint for this rig
Yeah, same here. All my gear is packed waiting to move to our new house. I'm excited though because I'll have a workbench!! Once things settle down, I know I have a ton of stuff to post and project updates.
Starting to warm up here. Need to test out some paint I have on the plastic. I need to clearance the hood and clean up some flashing and then I can paint
  • 3 months later...
Truck is finally getting some attention, all
the molding seams have been sanded and I need to go over everything and get ready to spray some paint. The back lid will be satin black. Main body I am hoping for a candy red. Bit humid to paint yet but hope to be done in the next couple of months. I still need a lighting kit for it and some better tires. Slowly getting there
  • 3 months later...
Looks great! Now that the weather is cooler here...mid 70s (24 C), I can be outside to do some painting too. Do you have any plans to add some LEDs? I've been checking out the cheap-o LED kits for some basic lighting. It's a clone so I'm not really wanting to add a Tamiya light set.
Yes going to do something. I saw there is a light kit for the blazer I will probably buy that one
all I know is this is a longer term project.. LOL. Took almost a year to paint it. I also need to do the interior
What is suggested to carpet. I would like to attempt to detail the interior instead of painting everything the interior color. Originally was thinking black but now wondering if tan/caramel color might be better
 @-=Jeff=- For simulated carpet have you considered hard felt?   They are easy to cut with a knife and retains shape.  You can source them locally from arts & craft stores like Michael's and JoAnn's.  It's like ozite material which is actually used for carpeting in some cars (like for trunk area, etc).
I use hard felt often for lining my RC's fenders.
Anyway, GL with your build!
I m thinking of this for the LEDs
https://www.rcgroups.com/forums/showthread.php?1539753-Open-Source-Lights-Arduino-based-RC-Light-Controller
Not really but that seems to have all the functions I want. Unless there is another solution that gives me the function of parking lights (no headlights) then parking with headlights and also no lights, like a real car. I could also program hazards too..
end of the day I like the the DIY stuff too
So the light controller does not have tail/brake/turn in one led. That I can tell, sort of sucks, but I will look for another
anyway.. body on chassis slowly getting assembled.
