Grasshopper123 3 Posted November 7, 2020 I have a black lunchbox. It will go forwards but not backwards! It’s been a few months since I tried to solve it. Previously it was going forwards and then cutting out. Now as if by magic forward works but no reverse. When I throttle forwards it goes fast. When I throttle back it stops the car but it won’t reverse. Any ideas please? Share this post Link to post Share on other sites
CoolHands 787 Posted November 7, 2020 https://youtu.be/Q1geQtlCNKE?t=662 written instructions https://www.wonderlandmodels.com/blog/article/tamiya-electronic-speed-controller-setup/ I see from previous posts you gave a brushed motor in, so you need to change the settings so the light blinks green. See video for that, about another 30 seconds after where it starts from my link. Share this post Link to post Share on other sites
Snappy1 964 Posted November 7, 2020 13 minutes ago, CoolHands said: https://youtu.be/Q1geQtlCNKE?t=662 written instructions https://www.wonderlandmodels.com/blog/article/tamiya-electronic-speed-controller-setup/ do you have brushed or brushless motor in it? Brushed motor , one of the motor wires is disconnected in the pic Share this post Link to post Share on other sites
CoolHands 787 Posted November 7, 2020 Yeah just realised. I think he has it set as brushless 1 Share this post Link to post Share on other sites
Grasshopper123 3 Posted November 7, 2020 Thank you for that. I have it set to brushed mode. Green on the ESC. Still forwards and no backward. Share this post Link to post Share on other sites
CoolHands 787 Posted November 7, 2020 Then it is radio settings (high point etc) or it isn’t working properly! I think. 1 Share this post Link to post Share on other sites
Grasshopper123 3 Posted November 7, 2020 Should I be replacing the ESC? I have a hornet too and that works fine. Would it be worth taking the ESC out of there and seeing if I can get the lunchbox to work? Share this post Link to post Share on other sites
CoolHands 787 Posted November 7, 2020 Yeah if you have another I would swap and test and if all else fails buy a cheap hobbywing 1060 from modelsport or fusionhobbies etc https://www.modelsport.co.uk/hobbywing-quicrun-1060-brushed-waterproof-esc-sbec/rc-car-products/404964 1 Share this post Link to post Share on other sites
KEV THE REV 2304 Posted November 7, 2020 I don't have this ESC , but is reverse dissabled on it ? , might just need the reverse setting put in to it's programme Just checked and full reverse is programmable - on or off , check the set up for full reverse on your ESC 1 1 Share this post Link to post Share on other sites
Wez-li 1790 Posted November 8, 2020 Yeah you can set this as forward only. In the instructions it can be set to forward and reverse. I have this esc and it just sits in a box cos its too annoying for words 1 Share this post Link to post Share on other sites
rwordenjr 1889 Posted November 8, 2020 Reverse being off is likely the issue but would be pretty odd if you haven’t previously messed with any settings because the esc comes standard with reverse on. 1 Share this post Link to post Share on other sites
Grasshopper123 3 Posted November 9, 2020 Any idea how to turn reverse on? Share this post Link to post Share on other sites
KEV THE REV 2304 Posted November 9, 2020 If you Google TBLE 02S manual you can see it on line with set up instructions. 1 Share this post Link to post Share on other sites
Grasshopper123 3 Posted November 9, 2020 Thank you ever so much to everyone who has responded to this topic. Those instructions look super complicated but I will give it my best! Share this post Link to post Share on other sites
Grasshopper123 3 Posted November 9, 2020 It works. Thank you so much! It’s only been sitting in the corner for 9 months! This forum is great. So many helpful people. 1 Share this post Link to post Share on other sites
KEV THE REV 2304 Posted November 9, 2020 😀 have fun !! 1 Share this post Link to post Share on other sites
