2 hours ago, Yoshimitsu said:
@svenb
Ah ok nice one, did you get the cibie stickers from the same seller?
It's those Monte decals Id like as well, did you get those on eBay too?
Ta.
No different seller for the Cibie stickers.
I had the monte decals specially made along with the castrol and dunlop.
I've a few spare sets which I will sell on.
Hey,
So I have found out the cause of the steering drift on this kit for me. The included servo arm shifts left and right a couple of degrees moving the centerline each time you go full lock.
I have a savox 230 with 25 tooth spline ( fyi with this servo you are forced to install it backwards and the horn won't align straight at dead zero due to the odd spline numbers, althought its not an issue as sub trim to center and epa for limits is down to 70% of max )
So is there a better servo saver horn to fix this drift issue?
7 hours ago, Yoshimitsu said:
A Colin McRae replica.
that's come up very well, and its the version I want to do whenever I get around to mine.
Will you try and do the side decals as well?
Can anyone help with where I can get this set of decals?
  • 6 months later...
