Hi, I have a Tamiya BigWig (2017 re-release) I am building.
I seem to be having a few issues with the steering / servo.
Radio gear is the Tamiya FineSpec 2.4Ghz system with TSU-03 Servo / servo horn
Turn on transmitter first and then when I turn on the RC car (switch on receiver) the servo turns to the left - hence steering is not straight.
Turning transmitter on and off from that point the servo then seems to rotate back opposite direction a few turns.
The steering trim setting on transmitter is in neutral.
End result is the steering is just not straight.
I 'think' I've set the servo up correctly in that servo was installed in neutral position
Transmitter and receiver paired as per Tamiya FineSpec manual.
Motor runs fine in forward / reverse, just the steering I'm having issue with.
Any help appreciated. Thanks.
