Trowa Jakuard 63 Posted November 15, 2020 Hi Everyone! I just finished a scratch-built Frog and am looking for input on what I should do for modifications. I currently have the 49T x 19T gears in it, a Redback rear sway bar on it, and some LED fitted pod lights. It also has a GoolRC 4370KV motor and a 120W ESC on 2S Lipo. I have a front sway bar on the way and would like to ask everyone for what they would like to see me do to it. Share this post Link to post Share on other sites
Frog Jumper 3661 Posted November 15, 2020 I can think of a lot of things... Terry Share this post Link to post Share on other sites
Trowa Jakuard 63 Posted November 15, 2020 I'm open to any suggestion! I'm new to the hobby and would love any tips Share this post Link to post Share on other sites
TurnipJF 9192 Posted November 15, 2020 MIP ball diff? Share this post Link to post Share on other sites
Trowa Jakuard 63 Posted November 15, 2020 I saw that it says it's for the Blackfoot monster beetle. will it work in the frog? Share this post Link to post Share on other sites
manny 83 Posted November 15, 2020 26 minutes ago, Trowa Jakuard said: I saw that it says it's for the Blackfoot monster beetle. will it work in the frog? You'll need the Blackfoot/Monster Beetle counter gear. You'll need the pinion gear too unless you have an aftermarket adjustable motor mount. Share this post Link to post Share on other sites
Trowa Jakuard 63 Posted November 16, 2020 KK. Added to the list! Share this post Link to post Share on other sites
Trowa Jakuard 63 Posted November 16, 2020 So, are the CV joints 100% needed for the ball diff also? and if so, should the boot be used on those too? Share this post Link to post Share on other sites
Trowa Jakuard 63 Posted November 16, 2020 . Ok. it keeps getting flipped no matter what I do................................ 1 Share this post Link to post Share on other sites
TurnipJF 9192 Posted November 16, 2020 From what I have read, I gather you can use the CV joints or the dogbones. Some sources even go as far as to say that the dogbones work better. The boots are part of the look I think, and work with either option. Share this post Link to post Share on other sites
Lee76 638 Posted November 16, 2020 6 hours ago, Trowa Jakuard said: Ok. it keeps getting flipped no matter what I do. Perhaps it’s a tree frog.. 2 Share this post Link to post Share on other sites
Trowa Jakuard 63 Posted November 17, 2020 18 hours ago, Lee76 said: Perhaps it’s a tree frog.. Ok, that's a **** good pun. The MIP Ball diff will be in tomorrow. I'm hoping the front sway bar will be here saturday. Is there anything Else you guys would suggest? Share this post Link to post Share on other sites
Toolmaker72 507 Posted November 17, 2020 Get it sitting lower perhaps with damped front suspension Share this post Link to post Share on other sites
Trowa Jakuard 63 Posted November 28, 2020 Ok! switched to a Super Stock BZ motor anda Hobbywing ESC, MIP Ball Diff, Front and Rear Swaybars, and front shocks. 2 Share this post Link to post Share on other sites
Trowa Jakuard 63 Posted November 28, 2020 Any suggestions on dampers and springs? Share this post Link to post Share on other sites
Frog Jumper 3661 Posted November 29, 2020 I used to have 50520s on the rear of my Frog but I switched them out for 50519s so the Jumper would ride lower. Still using 59519s in the front but I think I’ll switch to something shorter. Not sure yet... Share this post Link to post Share on other sites
