Dr_GN 16 Posted November 26, 2020 All, I'm going to treat my old '84 Frog (re-furbed) to a ball diff for Christmas. Modelsport do them, but list them only for Blackfoot and Monster Beetle. I've asked the question to Modelsport about if it's compatible with the original Frog, or if not, what parts I need to make it right (got no reply as yet). From the CAD image, it seems like the diff output shaft stubs are not the hex drive versons I've got: I've no problem in swapping them for other types, or swapping the driveshafts and outer cups, so long as they're Frog compatible. Has anyone fitted a MIP ball diff to a Frog, and if so, what parts do I need? Any other options? Thanks! Share this post Link to post Share on other sites
Frog Jumper 3661 Posted November 26, 2020 If I remember correctly, the MIP diff gear requires the BF/MB spur gear. You’ll also want an adjustable motor mount to use to larger Frog pinions on the BF spur. Terry Share this post Link to post Share on other sites
Dr_GN 16 Posted November 26, 2020 Thanks, I can get those gears I guess, but the driveshafts are different. I think I'll need some of these: https://www.timetunnelmodels.com/live/catalog/tamiya-19808038-9808038-drive-shaft-2pcs-58354-frog-p-16256.html and these: https://www.timetunnelmodels.com/live/catalog/tamiya-19808039-9808039-wheel-axle-2pcsfor-58354-frog-p-16257.html Do the original rubber bellows boots fit over these I wonder? Share this post Link to post Share on other sites
Dr_GN 16 Posted November 27, 2020 Actually, I think I'll use the countersunk screw method on the original diff, and save myself £100. 1 Share this post Link to post Share on other sites
Mrowka 496 Posted November 28, 2020 I wish M.I.P. would get to work and make me a Fox/Novafox ball diff. Share this post Link to post Share on other sites
Frog Jumper 3661 Posted November 28, 2020 1 hour ago, Mrowka said: I wish M.I.P. would get to work and make me a Fox/Novafox ball diff. Thorp made one. It’s rare and expensive though. Terry Share this post Link to post Share on other sites
Dr_GN 16 Posted December 3, 2020 Still works smoothly, but can't be cammed apart. When the thread retainer is set it should be sorted. 1 Share this post Link to post Share on other sites
