Well, I'm back. Haven't had much time to check the forums or play around with the Monster Beetle. Finally had a chance to run a couple battery packs worth through it.
Differential seems to be working as best I can telll, but the new problem is that the half shafts (dog bones) are spinning inside the cup area of the wheel shafts. Tried turning one of the dog bones around and that helped -- but only for a minute. I think the inside of the cups are wearing away. I know these things weren't this fragile when new...
So, any solutions out there? Any ever get brave enough and cut slots in the cups on both sides (diff side and wheel side) so that you could run more modern half shafts with the pins?
Thanks again...
Are the parts available separately anywhere on line yet? I see the Frog being sold. How about the parts as you describe?
Thanks.
nice title [;)]
i'd bet good money that "modelbuild" will be stocking up on frogs and breaking them up for bits, they seem to do that with many other kits creating an excellent spare parts service for vintage tamiyas.
if you can wait long enough, parts should turn up [:)]
Modelbuild is a uK based eBay store. I haven't used them myself but they usually have an interesting selection of parts.
You really should check them out since they currently have the Monster Beetle Joint shafts (both long and short).
My brother used some Kyosho TF-4 universals for his Frog and they worked out fine (some modification was perhaps necessary but I can’t remember).
id="quote">id="quote">
I saw that- what's the diffence between the long and the short? (besides length) Is one set for the Frog/Brat?
I don’t have any Frog based car but after checking the manual here on Tamiyaclub I would say that the short joint shaft is for the transmission. I think Tamiya calls it gearbox joint today. And the long joint shafts are what are now known as a rear wheel axle.
Somebody please correct me if I’m wrong but I feel pretty certain I got it right.
Pretty much what I was thinking.. but, are the Frog and Blackfoot axles the same?
(hold that thought- I've got both models here so I will check real quick...)
Yes, Frog and Monster Beetle/Blackfoot drive shafts are all the same.
Short joint shaft is the gearbox joint, long joint shaft is the axle and half shaft is the dogbone.
Normally, the problem is that the corners of the hex ends on the half shafts wear out. Are you sure the problam is with the joint shafts?
- James
Hunter Zero -- yes, I'm sure. While the corners of the hex ends are a bit worn, I can tell the cups are wearing because if I just assemble them by hand (not on the car), the half shafts spin freely when pushed all the way into the cup. If I back them out a bit they are actually farily tight. I could put a little something inside the cup area of the shafts to keep the half shafts from bottoming out in the cup area, but then I'd be afraid that I would be stressing some of the arm/chassis mounts for the suspension. (Because I would be forcing the trailing arms to push out a little bit.) Hope you follow what I mean...
Ben
That custom RC system is nice but $99! I could almost buy an RTR Stampede for that much... (well -- at least get closer...)...
Thanks for the info! I'll check out ModelBuild too...
Had another thought -- wouldn't the pieces from a Super Blackfoot just drop right in? I know the King Blackfoot had wider suspension arms, so the dogbones for that were probably longer, but the Super Blackfoot pieces should fit, right? I can a find all the parts on the web -- unfortunately with shipping it would cost something like $50 or $60 to get them all. But IF Tower or someone starts carrying the new Frog pieces, then I think I'd be able to get all the parts from ONE source and get it all (including shipping) for closer to $25-$35...
No
Super uses king sized parts, maybe a twin det/dagger dogbone would fit
The Super Blackfoot has a completely different rear end, a new gearbox (same as the Bush Devil) and double wishbone rear suspension. The actual dogbones are almost twice the length of the Monster Beetle ones.
see this previous post...
http://www.tamiyaclub.com/xforum/topic.asp...foot,shaft,ta02
I've got these parts on order. So, I'll know for sure in a few days. BTW, the Super Blackfoot and the King Blackfoot have 70mm dog bone shafts.
Personally, i'd buy the custom RC conversion, as he's just a moddler liek us, trying to supply us with helpful mods to our cars, which must be a problem spot.
As for the diff, i'd use tamiya lube, or something meant for a differential.
