Ordered this in May but covid impacted delivery and it only came in at the beginning of Oct....
it’s a very nice kit :)
and builds differently to many other kits - but a bit like the mantaray
so you build each diff first
Adding the suspension set up off the side of each diff
Rear:
Front:
with the very interesting articulation of the steering joints
Then because the chassis is not really a bathtub style one, you install the top deck and part of that top deck is the pre moulded driver
this holds up the build somewhat as you need to get the brushes out midway :)
and then the helmet - I gave it a primer coat first then use humbrol on top
And used part of the racing harness decals
then this top half of the of the chassis bolts onto the diffs
JJ
Once the top deck was added, things like the ARBs could be fitted
now....the reason I ordered a hotshot was because of the funky suspension layout
And being an engineer I was eager to see how it all worked
building up the 2 x chunky shocks
which are pretty normal shocks inside some red casings
the mechanics of the front are pretty simple - sort of like pushrod suspension
however the rear set up is pretty ingenious
Up/down movement turns into left/right movement turns into up/down again which then rotated around a pivot at the top and compresses the spring
JJ
And finishing off the chassis
Frame on...
and then the metal roof
and the small access panel for people with v small fingers - assume it was there to swap crystals maybe? Answers on a postcard?
Weird little machined metal trim pieces
front bumper
and here’s the driveshaft from underneath - the FRP battery cage makes the back half of the floor (like the wild one) and there is the second half of the chassis at the front which I didn’t get a pic of
JJ
Cutting out the body using the score and fold and painting was pretty simple
box art silver backed
With decals
Then matte black spray of the spots
and I cut the spot decal out close rather than just having the round decal
just waiting for my gold wheels to arrive and it’ll be finished
JJ
The "Weird little machined metal trim pieces" are replicas of the original heatsinks that the Hotshot wore with distinction, much better looking than the ceramic based ones B)
Great info - thank you :)
JJ
3 hours ago, foz75 said:
Looks good, mine is still unfinished... Which gold wheels, and where from? Am leaning towards box art but with gold wheels too...
The super hotshot ones - ordered those in May and might get them Jan/Feb
Tony Tamiya sorted me out on it all
JJ
  • 3 months later...
At last....!!!
the gold wheels finally arrived
10 months after I paid for them - covid haha
so I finally got to finish the hotshot and i think it looks amazing
Another project to hang on the wall
JJ
