Re-Bugged 10008 Posted December 3, 2020 Just wondering if I’m on the right track here in the middle of a 3 speed gearbox assembly. What I have a slight concern about is are the bearings in part J7 meant to be secured? There is no mention of it in the manual, but as J7 would slide along the shaft it would appear the the bearings can slip out of the housing in J7 leaving it to flop about. Bearings in place... Then simulating J7 sliding it would seem to leave the bearings to slip out?... Any pointers would be greatly appreciated 👍🏻 Share this post Link to post Share on other sites
Beetlemankurt 676 Posted December 3, 2020 Mmmm....I’m guessing it could be a typo in the manual. Here’s a pic of the Scania manual with the same shaft and gear. It recommends instant glue which is what I did (carefully).....:). Mine still works so must be ok! hope this helps Cheers Kurt 1 Share this post Link to post Share on other sites
Beetlemankurt 676 Posted December 3, 2020 Re-Bugged, also note though that the Scania manual says NOT to replace these particular bushes with bearings..... 1 Share this post Link to post Share on other sites
Re-Bugged 10008 Posted December 3, 2020 Thank you @Beetlemankurt 👍🏻, Tamiya must have been saving money on printing ink for my manual 😉. I watched this YT clip and this gearbox would seem to run with the bushings having slid out, but I can’t say I like the idea.. I believe that @topforcein has replaced all his bushes with bearings (from a dodgy memory) without an issue? I’ll have another look when I get a chance. Share this post Link to post Share on other sites
Wetman 417 Posted December 3, 2020 5 minutes ago, Re-Bugged said: Thank you @Beetlemankurt 👍🏻, Tamiya must have been saving money on printing ink for my manual 😉. I watched this YT clip and this gearbox would seem to run with the bushings having slid out, but I can’t say I like the idea.. I believe that @topforcein has replaced all his bushes with bearings (from a dodgy memory) without an issue? I’ll have another look when I get a chance. don`t like that idea. I thought part of bushings/bearings job was to help the part slide on the shaft as well as rotate freely. with bearings that come out theres a chance the gear is going to ctach on the bearing and not seat properly causing it not to engage gear and eventually damage to the gear. Side note, the volvo manual is different yet again with no mention of instant cement and no instruction not to replace parts 1 Share this post Link to post Share on other sites
Mad Ax 9149 Posted December 3, 2020 My MAN TGX manual definitely states to use instant cement here, and also not to replace with a bearing. I guess there is a risk you could get cement into the bearing and seize it. 1 1 Share this post Link to post Share on other sites
Re-Bugged 10008 Posted December 3, 2020 Cheers @Mad Ax, it sounds like there are discrepancies across the board with the manuals? The only thing in my manual that I’m advised not to change is the motor!! ‘Use only the motor supplied in the kit’ It says 🤔 I was thinking the same as you on seizing the bearings with glue. So I’ve bitten the bullet and glued the bearings in with a small dot in a few places, then checked the inner part still spun freely, then bolted the rest up and a bench test looks to be promising. 1 Share this post Link to post Share on other sites
topforcein 1764 Posted December 3, 2020 you know what ....with how my memory is recently (really really bad) i cant remember what i did i would have to take the gearbox apart to see what i did but you can def change the motor ... i mean why would tamiya release the tr tuned truck motor(witch i have in both my trucks) i wpuld say they can't be bothered to update the destructions 2 Share this post Link to post Share on other sites
berman 5315 Posted December 5, 2020 Speaking of aging memory, I remember reading somewhere there was supposedly a running change to the gearbox when the Scania was released, have no idea what it was though. All mine use bearings in place of the brass bushings, never had any ill effects. 1 1 Share this post Link to post Share on other sites
JYCM3 236 Posted December 5, 2020 I remembered I got confused on this step for the high-lift Hilux. manual says do not use ball bearing But I got the full ball bearing set for the Ford Hi-lift and I have 2 extra bearings left when I decided to follow manual recommendation using bushings instead. Then why would Tamiya have extra bearing in the set when this step does not recommend using bearings... 1 Share this post Link to post Share on other sites
