I built this truck a few years ago, I'm sure I've posted it here before.  It's a TXT-2 chassis mated to Clodbuster axles via custom 4-link bars.  Running a HW 880 ESC with dual 15T Firebolt motors, Traxxas aluminum big bore shocks, and replaced the stock aluminum TXT side plates with lexan to save weight.
I hadn't run it much after building due to some geometry issues I needed to figure out and finally decided to look into it.    Ended up re-doing the 4-link bars and tweaking the shocks a bit and now it works really well.  Put some new JConcepts Tribute Wheels with Firestorm tires and realy like the look now.  If you have spare Clod axles lying around grab some TXT-2 chassis plates and put them together, I can guarantee you'l llike the result.  And yes, I plan on trimming the body posts at some point :)
  • Like 11
