Hi all, newbie here!
im running a stock tt01 e (only change is steel bearings)
I have a
TBLE-02s ESC
Absima stick controller
Absima R3FS reciver
In the instructions it’s says the Absima is already “matched” and setup as a brushed motor.
the steering works and so does the acceleration AND brake. But NO reverse.
I have tried the RED-GREEN-AMBER-RED instructions. I get the beep but still nothing.
do you sugggest rebinding? Or anything else I have missed?
thanks!
Just to add...
I have noticed when I double tab forward it goes into reverse. Then I need to tap back to stop it... very strange going on’s...
driving me mad!!
2 hours ago, Pri5tt01e said:
Just to add...
driving me mad!!
Did you try reversing the throttle channel on the transmitter?
Currently the transmitter is set to
TH - Nor
ST - Nor
if I set TH - Rev the controls switch direct but work... so forward goes reverse and back goes forward.
it’s like Iv got somthing on the electrics crossed!! Annoying!!
TH - Nor
ST - Nor
You said above you're using a brushed motor? Try leaving the TH in the Rev position, and swap the motor wires.
Yes brushed.
so currently I have
yellow - yellow
blue - green
are you suggesting I swap them around?
12 minutes ago, Pri5tt01e said:
Yes brushed.
so currently I have
yellow - yellow
blue - green
Yes, exactly. So you should have:
yellow - green
blue - yellow
The wire colors may not match, but that doesn't matter as long as the car moves in the correct direction (with brakes when you push the stick to reverse).
yellow - green
blue - yellow
Legend! such a simple change and it worked - first of many things to learn!
problem I have now.... :)
when Im in reverse and then hit the throttle it stops i.e. brakes, if I do the same when I have the throttle down and then hit reverse it does straight into reverse.
From my (limited) understanding I think it supposed to stop i.e. brake so the gears dont get f'ed.
ok so i think I need to switch the motor wire back to
yellow - yellow
blue - green
Because it seems to go a lot fast in reverse if I swap them around, and I also get the above issue.
So back to square one... Cant get car into reverse!
yellow - yellow
blue - green
Yep, well we at least eliminated some variables from the equation. It's not the Tx/Rx, it's not the motor, and the ESC thinks fwd/rev are the correct directions.
I don't actually have this ESC but I finally just looked up the manual. I think what you described in your first post is just how it's supposed to work?
https://www.tamiyausa.com/media/files/45057ml-801-efb9.pdf
Quote
*Caution: Return the trigger to neutral (stop) position, then push it forward again to drive in reverse.
Thanks so much for your effort in looking into this! Yes the more I read about it it seems the norm..
i.e having to brake (neutral) the  again hit thorrotle to reverse. So, the reverse is technically just to brake.
not sure I’m happy with that, as it’s a bit temperamental, getting in reverse. Some times works sometimes just goes forward.
So is it the receiver or the ESC that controls this communication. As in what do I need to replace if I want this working as I first suggested.
thanks
Put the transmitter throttle switch into reverse position and then go through the process of calibrating the esc high / low end points as per the manual from the beginning again.
thanks
It is the ESC that controls the fwd/brake/reverse setup, yes. I have the same troubles with my Traxxas XL-5 ESC, except I have to return the stick to neutral after hitting the brakes, and then reverse is the normal reverse direction on the stick. But it's the same "fiddlyness" where the ESC thinks you still want to brake, so it doesn't kick into reverse on the first try, and it's even worse if the steering is turned. I basically have to wait for it to come to a dead stop with the brakes on until I can return to neutral and then reverse. My Hobbywing 1060 is the same procedure as the Traxxas (fwd-fwd/rev-brake/double tap rev for reverse), but in yet another difference, it seems to want to kick into reverse more often than the brakes.
It’s working!!!
not sure how...
I was out giving it a run and the grub screw in the pinion gear must have come lose and the motor was revenge but the car stopped moving! I removed the parts and greased and tightened the grub, turned it all back on and it’s working!!
So now, one pull back engages the brake  then second pull back puts it in reverse
setup...
motor wire as stated in manual B-G / Y-Y and TH in Nor... all same as original when I first posted!!
if anyone can shed any light on this it would be a great learning point!!
Now to make the steering straight (keeps turning right) then to make it go faster :)
Did you set the steering trim on the transmitter?
Yep! It’s so far out it hardly helps.
im sure  it’s because  Iv knocked it and the servo is out. Can’t be this bad normally. It was fine at own point...
  • Confused 1
