StuHU 2 Posted December 28, 2020 Hi all. After a year of bashing an FTX Carnage to bits (and considerable cost to rebuild) I decided to build a new car for my lad. Decided on the DI primarily becuase that's all that wan in stock! Anyway, really enjoyed building it over Xmas and added some hop-ups for good measure. One problem though; turn left and the steering centres okay, turn right and it stays offset to the right. I've tried trimming it on the tx but it's not enough. I set the length of the turnbuckles using a ruler but I have picked up my calipers today so I can check them all more accuratley but I'm positive they'll be as per manual. I've attached a photo showing how the wheels sit after turning right. What am I missing? 1 Share this post Link to post Share on other sites
Superluminal 3729 Posted December 28, 2020 Did you set the centre point of the servo correctly prior to attaching the servo saver? Share this post Link to post Share on other sites
StuHU 2 Posted December 28, 2020 I operated the servo before fitting the horn, but now you've menioned it I'll check it again! Share this post Link to post Share on other sites
Superluminal 3729 Posted December 28, 2020 Thats the only thing I can think of - that the servo is in its neutral position as shown in the photo. Make sure the transmitter trims Re neutral too unless using a separate servo tester. I cant recall any of the dark impact steering parts ever binding on mine (unless the servo is faulty) 1 Share this post Link to post Share on other sites
Juggular 4914 Posted December 29, 2020 Might be a bad actuator in the servo? If it centers alright after left turn, but not after right turn, then the limiting thing (actuator) might not be working properly. If you have an extra servo, I'd try that. Share this post Link to post Share on other sites
StuHU 2 Posted December 29, 2020 I've had a thorough look over and can only marginally improve matters. Might well have to try another servo. Share this post Link to post Share on other sites
