M06Guy
Futaba S3004 BUZZING
Just finished my M-06 build and I'm getting quite a loud buzz from my steering servo(Futaba S3004). Is this normal? I took off the servo saver just in case there was some binding but it makes the same noise even when not connected to the saver/steering rod.
Should I be using a digital servo instead? Some other issue?  I have the transmitter set to 22ms rate.
Transmitter: Spektrum DX5C
Receiver: SR6100AT
ESC: TBLE-02S
Thanks for the help!
1 hour ago, Champ85 said:
From page 4 of the Spectrum DX5C manual:
I did disable the AVC but yeah, that's probably the culprit.
Any suggestions on digital servos?  New to the hobby after a few decades off.  Never had digital before.  Thanks!
I'd suggest a Spektrum servo so that you are doubly sure you don't get any compatibility issues. The M-06 doesn't need a high spec servo (very little load), so just a "standard" digital servo should be enough.
