M06Guy 10 Posted January 8, 2021 Just finished my M-06 build and I'm getting quite a loud buzz from my steering servo(Futaba S3004). Is this normal? I took off the servo saver just in case there was some binding but it makes the same noise even when not connected to the saver/steering rod. Should I be using a digital servo instead? Some other issue? I have the transmitter set to 22ms rate. Transmitter: Spektrum DX5C Receiver: SR6100AT ESC: TBLE-02S Thanks for the help! Share this post Link to post Share on other sites
Champ85 609 Posted January 8, 2021 From page 4 of the Spectrum DX5C manual: 1 Share this post Link to post Share on other sites
M06Guy 10 Posted January 8, 2021 1 hour ago, Champ85 said: From page 4 of the Spectrum DX5C manual: I did disable the AVC but yeah, that's probably the culprit. Any suggestions on digital servos? New to the hobby after a few decades off. Never had digital before. Thanks! Share this post Link to post Share on other sites
sosidge 624 Posted January 8, 2021 I'd suggest a Spektrum servo so that you are doubly sure you don't get any compatibility issues. The M-06 doesn't need a high spec servo (very little load), so just a "standard" digital servo should be enough. Share this post Link to post Share on other sites
