12 minutes ago, Seanster43 said:
They are great chassis even though older still very capable. Can still get plenty upgrades for it as well!
Thanks for reply... Have you had one of these and what t pinion did you use on the stock spur?... I tested it tonight but only had a 27t for the stock 48pitch and acceleration was slow...
There’s a few build threads on here worth a nosey a few guys have converted there’s to a TRF spec, I’ve got a TRF201 still working in getting a few bits for it as was a basher that needed some tlc. What motor are you running?
I was planning on leaving this kit standard as I think it's good enough out the box performance wise... Not really decided on motor yet, but was contemplating sticking with a full tamiya brushless set up... I tested it tonight with an old 2700kv smd brushless set up... Was smooth but slow on acceleration... Thinking that might have been down to gearing though as I only had a 27t pinion to hand
@Kelleye Great buggy. I have 3. one is pretty much a trf201. Get the slipper correct and its a fun kit. Im running 3250 kv brushless. Fast enough. However i did melt diff once.
I have a zahhak and trf201, they’re okay but the steering is really lacking. You don’t notice it much until you go to track and run. Pretty good basher though
I find the steering okay, but both my trf’s have had the alloy steering kit so not sure if that’s made a difference. They are quite light at the front.
I mean the sharpness of the steering. The DT03 for example is miles ahead in steering.
    • IXLR8  »  Clappy75
      Hi Jon,
      https://flic.kr/p/2roEkj2
      Doug
      · 0 replies
    • WhteRbt
      · 0 replies
      · 0 replies
      Hello
      Hope you are well
      Thank you for your help
      Kind regards
      Jack
      · 0 replies
    • seoondaddy
      Seo-onDaddy - YouTube
      · 0 replies
