KEV THE REV 2304 Posted January 23, 2021 Check the wiring to the motor , the motor wires need to be reversed as your foreward is actually reverse and reverse is foreward . You bought a Tamiya TB ESC not the Hobbywing 1060 then ? . Share this post Link to post Share on other sites
GarethMck 9 Posted January 23, 2021 Oh my god. That's a little.embarrassing, cheers man. 1 Share this post Link to post Share on other sites
KEV THE REV 2304 Posted January 23, 2021 On 1/21/2021 at 5:31 AM, Frog Jumper said: Looking at the links above, those are the wrong hex adapters... You want these, which are fit the DT03 cars: https://www.gpmparts.com/tamiya-dt03-aluminium-front-wheel-hex-adapter-with-bearing-2pcs-set-for-gpm-optional-wheels-dt3010f-p-90067717.html I tried using these before , but I found that when the wheel is put onto the axle with the adapter and you tighten up the nut , the wheel isn't stable at all and flops around , and if you tighten the nut up to press against the wheel as it would on a stock front or rear , it binds the bearings and stops rotation Share this post Link to post Share on other sites
GarethMck 9 Posted January 25, 2021 Morning gents, Does anyone have any handy web links to some Blackfoot wheels that will fit my sons frog? Thinking of taking the advice of going with BF wheels and adapters and swapping out the front bumper as well for the BF one which is probably a good move for long term fitting of wheels.. I have had a look myself for quite awhile now, any advice on the following links if they would work or not would be awesome. https://www.ebay.co.uk/itm/NEW-TAMIYA-BLACKFOOT-2016-Wheels-Set-Front-Rear-TEC-/312014111503 these ones all look the same size which may look a bit odd as I think he wants chunky front wheels that are slightly smaller than the rears (think boomerang look) https://www.ebay.co.uk/itm/Tamiya-Vintage-Monster-Beetle-Wheels-Tyres-Rc-Car-Spares-Blackfoot-Mud-Blaster/373433518900?hash=item56f25f4b34:g:9CAAAOSwuxlgBz0F not sure these would fit as require 12 mm adapters? https://www.ebay.co.uk/itm/RC-4Pcs-1-10-Rubber-Rally-tyres-tire-Wheel-Rim-12mm-Hex-For-HSP-HPI-Off-Road-Car/124386313544?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200520130048%26meid%3Da6e43a4dbb1d4cfa87d265b0def6142e%26pid%3D100005%26rk%3D1%26rkt%3D12%26mehot%3Dco%26sd%3D373433518900%26itm%3D124386313544%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithDarwoV3BBEV2b%26brand%3DUnbranded&_trksid=p2047675.c100005.m1851 cheers ps, as an update, them cheap and cheerful wheels I bought and linked a good few posts up, there is a reason they were cheap and cheerful, first corner the boomerang took with them and the tyres slid off the rims... oh well, only a tenner eh. Share this post Link to post Share on other sites
Dweeb 8 Posted January 25, 2021 I'm fairly new here and certainly no expert. I've been using similar cheap wheels and tyres. You need to glue the tyres to the rims, I used a tiny dab of superglue at 12, 3, 6 and 9 positions on both sides of the rim. 2 Share this post Link to post Share on other sites
KEV THE REV 2304 Posted January 25, 2021 I haven't tried this yet , but maybe Lunchbox / Pumkin wheels & tyres might fit - same issue with bumper I would say . I'll have a try later Share this post Link to post Share on other sites
KEV THE REV 2304 Posted January 25, 2021 In the mean time , how about this https://www.ebay.co.uk/itm/4pcs-Tires-with-Wheels-for-TAMIYA-1-10-Frog-buggy/133627602180?hash=item1f1cd36504:g:l7oAAOSw1LpetDPo or this - these are Lunchbox size wheels https://www.ebay.co.uk/itm/4pcs-tires-set-for-TAMIYA-Grasshopper-Hornet-Frog-Subaru-Brat-Grasshopper-2/254648492671?hash=item3b4a3ba27f:g:CMUAAOSwr~ZfBwze Share this post Link to post Share on other sites
GarethMck 9 Posted January 25, 2021 the first ones are lovely Kev, although 40 quid all in and a long wait for them to arrive from china sadly, but if thats the going rate for decent wheels and tyres, so be it eh I do like these ones Frog Jumper suggested, but cannot seem to find em anywhere 1 Share this post Link to post Share on other sites
KEV THE REV 2304 Posted January 25, 2021 Kyosho Scorpion wheel / Proline tyres . The wheels are available , tyres might be difficult to find here . I did fit Kyosho Tomahawk wheels and tyres to a Sand Scorcher . Front go straight on with a 850 bearings , the rear needed work as they are compression fit as standard 2 Share this post Link to post Share on other sites
GarethMck 9 Posted January 25, 2021 yeah think I found the Kyosho Scorpion wheels on Modelsport.co.uk so thats cool, https://www.modelsport.co.uk/kyosho-front-wheel-2-scorpion-2014-white-2-2-inch/rc-car-products/429621 out of stock but could order them and the rears they have as it does say order on request so fingers crossed. tyres though.. hmmm, Frog Jumper can you remember where you sourced yours from mate? Share this post Link to post Share on other sites
Frog Jumper 3605 Posted January 25, 2021 9 minutes ago, GarethMck said: Frog Jumper can you remember where you sourced yours from mate? TBH I don’t remember but I suspect I got them in a tub of vintage wheels and tires I scored on Craigslist. That said, I use eBay to source most of my tires. Terry Share this post Link to post Share on other sites
GarethMck 9 Posted January 25, 2021 Yeah, I have been on ebay more times this last few weeks then the last few years think my box of grasshopper2 bits has just arrived... thats this evening sorted... (suspect my wife is thinking I am having some kind of midlife crisis) 1 Share this post Link to post Share on other sites
Exit13 673 Posted January 25, 2021 1 hour ago, GarethMck said: (suspect my wife is thinking I am having some kind of midlife crisis) ^^^This 1 2 Share this post Link to post Share on other sites
KEV THE REV 2304 Posted January 25, 2021 30 minutes ago, Exit13 said: ^^^This Spot on Share this post Link to post Share on other sites
