curtmcgirt 2 Posted January 20, 2021 The manual says the steering rods are 63mm and 80mm. Did they never use these sizes in other sets specifically re-releases? I was looking at grasshopper, grasshopper 2, and hornet, but theirs are shorter. What's a suitable replacement? Share this post Link to post Share on other sites
67CamaroSS 304 Posted January 20, 2021 Go out and buy a threaded rod. Any hobby store that sells planes should have it. Then just cut it to length. You can buy a 3mm rod to use the stock ends or a 4mm for a more heavy duty application but you'll need bigger rod ends, which you can also buy at the hobby shop. Share this post Link to post Share on other sites
Problemchild 2149 Posted January 21, 2021 23 hours ago, curtmcgirt said: The manual says the steering rods are 63mm and 80mm. Did they never use these sizes in other sets specifically re-releases? I was looking at grasshopper, grasshopper 2, and hornet, but theirs are shorter. What's a suitable replacement? You can buy them (I know I had to) do you have the part numbers? JJ Share this post Link to post Share on other sites
curtmcgirt 2 Posted January 21, 2021 5325005 5315009 I would buy them if I could find them. I may go down the threaded rod route. Share this post Link to post Share on other sites
Problemchild 2149 Posted January 21, 2021 @curtmcgirt Actually I’m fibbing I bought racing fighter parts 75mm and 59mm JJ Share this post Link to post Share on other sites
curtmcgirt 2 Posted January 28, 2021 the stock rods are 2mm, not 3. but amazon has them in various lengths, threaded on both ends. so i can cut them in half and z-bend them. thank you. Share this post Link to post Share on other sites
