Just a question regarding micro-set and micro-sol. Where can I get it??  All uk suppliers seem to be out of stock. Postage from US is prohibitive.
Bill W.
3 hours ago, Heliwilly said:
Jeremy,
I realised that and edited my post, two above yours. My mistake for not looking properly in the first place!!!
Cheers Bill W.
Have you tried Hannants for Micro sol/set
Hi All,
Change of plan.
I was going to build a New Old Stock Honda CB750 Racing Type, as I had already built one, and enjoyed it, so I bought this new old stock one.
Since then I have decided that I would rather build another Africa Twin in the alternative paint scheme.
If anyone has an unopened Africa Twin  and would like to swap. I would be interested.
Rather than buy another kit I would like to swap it.
With the CB750 Racing Type, because I had problems with the decals on the one I built, I got RC Decals to make me another set.
Bill W.
PS
Just looking on Fleabay, and there are none available in the UK.
I will leave it on here for 7 days. If no swaps, it will go on Fleabay.
Bill W.
Now posted on Fleabay. Bill W.
On 1/12/2022 at 9:43 AM, alvinlwh said:
Usually, you should not need Softer unless you are applying decals over, say a 1/35 tank engine grills.
Hi alvinlwh,
I used the  Mr Mark Setter on the fairing numbers of a Tamiya Honda CB750 racing type motorcycle. The flatter surface side numbers went on OK. The number on the nose of the fairing is made in 2 halves as the nose is a complete double curve. These went on OK but would not conform to the shape of the nose. I have left it for now but would like advice on what strength of tamiya, strong or super strong to use to get it to drape over the nose of the fairing. Any other  advice gratefully received.
Bill W.
2 hours ago, alvinlwh said:
If that fails, next one to go on is Mr Mark Softener (Green cap).
https://www.wonderlandmodels.com/products/mr-hobby-mr-mark-softer-neo/
"Mr Mark Setter should be applied to the surface where the decal is to be applied to help the decal stick to the surface. Once dry Mr Mark Softer should then be applied to the top of the decal. To help the decal to conform to things like panel line and rivets. Leave the decal for a few hours to comply dry."
The strongest is Microsol (red), an almost" one shot" solution for really complex decals, but that, you said is sold out all around the UK?
For Tamiya, I believe their Decal Adhesive is weak while Mark Fit is strong. However, they are actually really slow in getting into the game with these liquids and by they time they did, I am already well invested in other brands so cannot advise you much on Tamiya's own brand.
Just ordered Mr Mark Softner. Fingers crossed. Bill W.
3 hours ago, alvinlwh said:
Remember, if it is as difficult a surface as you say it is, it may require more than one application. Thing about Tamiya decals is they are often too thick and don't form well to difficult surface. This is well known in the static world.
As you say, the Tamiya decals are fairly thick. I will see how it reacts to one coat and take it from there. Thanks Bill.
I managed to get the Microscale Set and Sol from Wonderland Models in Edinburgh. Arrived in 2 days. Excellent customer Service and the products were very well packed. They both seem to have worked very well indeed, eliminating problems with double curves decals draped very well with the micro-sol.
Bill W.
Well, it seems that after about a year on and off the Africa Twin is completed. There are things I would have done different order but overall I am very happy. I am really glad that I did the metal spoked wheels.
Plus another two Hondas.
