Just found out the stickers are not pre cut, cut one out and lost the will to live. 😩
Whats the best method, the GWagon stickers are a real pain, lots of curves.Ā
I use a scalpel, cutting board, lots of patience and, ahem, a clearĀ work area ;)Ā
That said, I don't really like doing it either - usually end up doing it at my desk with limited space, offcuts of backing paper absolutely everywhere and some lame film on Prime that I see about 5% ofĀ
fwiw. although initially it feels like a pain to have to cut each individual part out separately, the problem withĀ pre-cut decals is they almost always have a clear edge around the coloured part, which can look a bit shonky, especially on a nicely painted body...
(...although generally speaking I like Tamiya decals as the plastic they are printed on is very thin, so the clear edges aren't too obvious).
Having to cut them by hand means you can take your time and cut really close to the coloured section - which for the trim details particularly, is going to achieve a far more professional looking end result.
Ultimately though, in this instance, with all the window surrounds etc. I can see how the process is particularly labourious - which is why I prefer hard-bodies and to actually paint the window surrounds and other details like that, rather than rely on stickers.
Sorry I can't be of more help... as Finnsellc suggests - a nice sharp hobby knife (X-acto or similar) plusĀ a metal straight edge I'd suggest;Ā and one or two butĀ not too many beers ought to see you right ;o)
Jenny x
Take your time, it always takes longer than you think so dont rush it as it looks like youve made a really good job of the paint and masking, even if you take a few days to finish it.
I just use scissors to trim just slightly around the outside of the printed decal and make sure all cuts around corners have curved smooth cuts, not sharp corners which can lift or catch on thingsĀ over time. Have a bowl of warm water with some fairy liquid in, submerge the stickers for a few seconds then apply to the shellĀ and gently stretch them around the curves. If they are still wet you can repostion them and when in place flatten down with a paper towel while squeezing out any bubbles. If I need the decal to shrink into a corner or around a tight bend I give it a quick waft over with a ciggy lighter. Any bubbles can later be popped with a bin to release any trapped air/water under the sticker.
Other than that; make sure you peel the film off first and wash your hands, stickers dont stick to well to shells covered in greasy fingerprints and if you inadvertantly get the sticker stuck on your finger and it has a transparent backing you will see your fingerprint in the decal on the shell forever after.
superluminal Ā  Some good tips , will try again. Messed up the rear screen surround , the warm water and fair liquid Ā must make it easier to position Ā
Big decals - scalpel and thenĀ use a spray of waterĀ
long thin - cut out and remove a small amount of the backing to positionĀ
using a scalpel enables you to remove as much of the clear as possibleĀ
on my Avante I even spent time removing the inside sections and as much of the clear between letters (without making the sticker fragile) and then laid it on using waterĀ
Jenny x
You ain't lyin . Case in point:
Ā
    • IXLR8  »  Clappy75
      Hi Jon,
      In the linked image, I've simply moved the bar forward until it is centered directly over the rear shock tower (approx. 10.72mm) and kept the same height. Ā Is this what you had in mind?
      https://flic.kr/p/2roEkj2
      DougĀ
      Ā
      Ā
      · 0 replies
    • WhteRbt
      Checking out this status thing…  And now with a beautiful avatar! šŸ˜‚
      · 0 replies
      · 0 replies
      Hello
      Hope you are well
      Thank you for your help
      Kind regards
      Jack
      · 0 replies
    • seoondaddy
      Seo-onDaddy - YouTube
      · 0 replies
