Hello,
I have the new Tamiya Ford Escort MK II which of course comes with the MF-01X chassis. As part of the purchase bundle, I have an inexpensive Tamiya-Carsen Low Profile Steering Servo CS3 with metal gears.
However, I have also got hold of the Yeah Racing Suspension upgrade suspension kit for this chassis, and it's recommended to use a higher torque steering servo.
So my questions are:
1. Is the Carsen-Tamiya CS3 up to the job?
2. If not, then which  steering servo should I use that will fit into the limited space for the MX-01X?
3. Does anyone have any experience of steering servo torque issues on the Tamiya MF-01X, particularly with an ugraded suspension?
Many thanks and kind regards. kitefighter
The cs3 as I understand it is a basic servo like the futaba 3003, perfectly fine for the job of the mf-01x, if the suspension kit has some alloy on it then a 9kg torque or higher would suit better, check out modelsport if in the uk
16 hours ago, kitefighter said:
By the way, what does a servo saver arm do?
As the name suggests, it offers protection to the servo gears. Most include a spring arrangement which absorbs some of the impact should the steering be forcibly deflected in a crash. They were pretty much vital back in the days of plastic-geared servos, however nowadays with tough high-torque metal-geared servos being more affordable, they generally protect the steering mechanism from being damaged when an impact tries to deflect the front wheels against the force of a strong servo.
Thanks for that. Can you tell me if the Tamiya 51000 high torque servo would be compatible with the MF-01x?
You will need to buy the aluminum long servo horn from Tamiya to go along with it; it does not work with the stock plastic horn. Tamiya Part# 54120.
