ahh gone and stripped the larger pressure plate on the Top Force rear diff MA17 (19805378)  (although MA18 the smaller pressure plate appears to share the same part number). I see they are available at Tamico but with brexit it will be a silly price I am sure - anyone know where preferably UK based where I could get any?
Forgot the they are sometimes listed without the leading 1 ie: 9805378 seems some places appear to be having them in next week.... I guess I need to glue them in better in future...
If I recall the instructions or it was a tip on here mention about applying threadlock on the splines to take out the slight play in the outdrive cups to reduce the chance of them stripping.
8 minutes ago, gizard said:
Yup there is i did glue them in but obviously not well enough....
They're not a great design really. I much prefer the rectangular block key type of the later diffs which i dont think any fit unless you swapped out the ball diffs for gear diffs but then the lack of slipper in a top force wouldnt do them any good.
Gizard, think i might have one in the parts bin. Let me check. If i remember right think i have the ta03 ones in my Top Force so should have the old ones left over somewhere.
Have searched the parts bins;
thanks for the help - i have ordered the ones from Tony's - wonder if superglue is the way forward for the outdrives into the plates...
