Morning all
My son took my old Hotshot 2 for a spin yesterday and its come back missing one front drive shaft. Can someone direct me to the replacement part please, hoping these are easier to source that the original Hotshot ones! Think they might be the same as the Boomerang?
And is there a way of using cable ties to hold them in place to stop this happening again?
Much obliged. P.
Don't know if the vintage & re-re driveshafts are interchangeable.
What length is the driveshaft you still have ?
Have you found anything else worn or broken which would have allowed the driveshaft to pop out ?
I am in the middle of bringing back a Vintage Boomer. I bought re-re inner and outer cups with the driveshafts you posted.
When the suspension is fully drooped... the one side binds. I believe this is common issue with the new driveshafts.
After reading up for a quick fix I ordered re-re Hotshot front driveshafts as they are supposed to be slightly shorter (9808128)
Also... keep in mind I have vintage gear cases.
Will report back once the new shafts come.
Thanks, other one is in the car for now, will report details when I can extract it. On first glance no, uprights look intact.
Brill thanks, advice would be appreciated.
Just got a chance to do a bench test.  No more binding. The 9808128 shafts are a tad shorter then the  9805551 shafts. Seem to be just enough. I do not know if you need the re-re cups as well?
Once again... the setup is a vintage Boomerang chassis, gear cases with the re-re parts in the links below.
https://www.ebay.com/itm/Tamiya-Hot-Shot-Super-Hotshot-Bigwig-Levant-9808128-19808128-Front-Drive-Shafts/293789621182?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
https://www.ebay.com/itm/NEW-TAMIYA-SUPERSHOT-Axles-Bearings-HOTSHOT-BOOMERANG-SUPER-TP2/132417181670?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
https://www.ebay.com/itm/NEW-TAMIYA-SUPERSHOT-Joint-Propeller-Shafts-Pinion-Gear-HOTSHOT-SUPER-TP9/312014122000?hash=item48a57dac10:g:UX8AAOSwIJlaH79w
On 3/6/2021 at 2:57 PM, DPR250R said:
Thanks, by way of an update I may have found a solution. Pulled out the remaining front shaft from my HS2 and measured it - 76mm. Not sure this is correct as looking at the ones I have in my super sabre they are 77mm (77.3 I think), so maybe the previous owner put shorter shafts in hence the fall out?
Work around for now, I have 2 spare original HS1 rear shafts (77mm) which seems to fit. Any reason these won't work? Re re shafts may need new drive cups I'm told to work with the HS2.
Cheers, P.
