Sign in to follow this
NightProwler17
M17/rx493 Help
Hey there...is anyone using the M17. I am having issues binding to my MMax Maclan 160A ESC. I can bind the ESC and servo just fine, but once i turn the receiver off and turn back on, only the servo works. Anyone experience this? ANy suggestions?
Have you tried another esc, or the same esc with another tx/RX set? You may need to work through the components to see which one is creating the issue. The M17 is a high end quality radio (doesn’t mean it’s immune to faults) as is a Maclan ESC. The easiest way to diagnose will be by elimination so replace one component at a time to test everything. Even try a different servo, they can sometimes appear fine, but will actually be the culprit in the set up
Sometimes computer radios set at 100% epa don’t have enough bandwidth for a ESC to be setup properly. Try setting the epa on your radio to 125-150% and see if that makes a difference. Not saying this is the problem but it’s something I’ve come across with my DX5R several times with some esc’s.
