Shodog 1835 Posted March 9, 2021 This will be my second 40th Porsche 934 build. I chose to use a black kit as I was lucky enough to purchase this kit before the prices became insane. I started this as a lockdown build in April of 2020 when I found out that Maxspeedparts was making a 230mm chassis. I got the rear gear case built and that’s where the project died. Because of German post policies and COVID issues the chassis I ordered never came And I ended up with a refund. I was bummed as that chassis was the whole reason for this build. Then on December 8th I took my chances again and ordered a set which sat in a German post office until it showed up today exactly 4 months later. Here you can see the size difference My plan for this chassis is to replace the chassis currently under my redmetal body. I couldn’t live with the wheel base issue. This will give me a nice 236 mm chassis to use for my Martini GT2. I plan to build this chassis the same as above with the sweet 53155 low friction dampers, Orion motor and Taisan silver gear cases, just 6mm shorter One thing I experimented with was adapting a set of the eBay aluminum disc brake kits to this chassis. The issue I found was the 6mm outboard bearing seat on the axle that interferes with the caliper bracket. I had my neighbor use his lathe to mill that bearing seat to 5mm for me. Now I can use the 5x8 outboard bearing in the caliper bracket. 7 Share this post Link to post Share on other sites
studioRS 213 Posted March 9, 2021 Nice! Following this build. 1 Share this post Link to post Share on other sites
Shodog 1835 Posted March 10, 2021 Next step of the build is to mount the shock tower. The holes for the shoulder bolts are not big enough. I used a #28 drill to enlarge the hole. Tore open two new packages of dampers. Gear cases complete Chassis finished. I used a set of aluminum Fuchs from RC4wd 6 mm is a huge difference. The chassis fits the body so much better. 15 Share this post Link to post Share on other sites
mtbkym01 4008 Posted March 10, 2021 Those wheels with that body is killer 3 1 Share this post Link to post Share on other sites
TurboRSR 356 Posted March 10, 2021 Looks really amazing with those wheels! I also bought a 230mm chassis kit from Maxspeedparts, but he first sent me a 236mm lower deck. When I got the correct one from him later, I saw that the weave pattern and the gloss was different from the upper deck that I had already got. A bit annoying, but it will probably not be that noticeable when it's built and the electronics is fitted. 2 Share this post Link to post Share on other sites
Juhunio 6830 Posted March 10, 2021 3 hours ago, Shodog said: Glad to hear you got your chassis parts in the end Did you cut down the prop shaft or deepen the recess in the prop joints? Those wheels are hawt I just went to the RC4wd website to take a look...ouch! They do really set off that lovely shiny paint job though It looks the biz! 1 Share this post Link to post Share on other sites
Shodog 1835 Posted March 11, 2021 16 hours ago, mtbkym01 said: Those wheels with that body is killer Thanks I bought them a couple of years ago. They are overpriced but very nice. Share this post Link to post Share on other sites
Shodog 1835 Posted March 11, 2021 15 hours ago, TurboRSR said: Looks really amazing with those wheels! I also bought a 230mm chassis kit from Maxspeedparts, but he first sent me a 236mm lower deck. When I got the correct one from him later, I saw that the weave pattern and the gloss was different from the upper deck that I had already got. A bit annoying, but it will probably not be that noticeable when it's built and the electronics is fitted. You’ll be the only one that knows the difference. I’m particular also. I bought a replacement chassis for one of my new built cars because I accidentally slipped with the screwdriver and scratched the chassis. Share this post Link to post Share on other sites
studioRS 213 Posted March 11, 2021 @Shodog Paint is really nice. Aubergine, Amethyst? Reminds me of two different colors, Audi Zyclam mica red on my 1990 90 20v quattro, and an early 1985 Porsche 944 Sport that fixed up and autocrossed. 1 Share this post Link to post Share on other sites
Shodog 1835 Posted March 11, 2021 3 hours ago, studioRS said: @Shodog Paint is really nice. Aubergine, Amethyst? Reminds me of two different colors, Audi Zyclam mica red on my 1990 90 20v quattro, and an early 1985 Porsche 944 Sport that fixed up and autocrossed. It’s a combo of clear red and gunmetal. 4 Share this post Link to post Share on other sites
Shodog 1835 Posted March 12, 2021 Used a press to smash the end of prop shaft and cut 6mm off of it. Tamiya really dropped the ball on this release. They could have made the 40th special by shortening the shaft And chassis then print 40th anniversary on the top plate like they did for their 30th anniversary chassis. I’m going to scrap the idea of the caliper brackets. Even with the milled axles their not working right. I’ll just use the brake rotors for hex hubs. Got the 236mm anniversary chassis set up for my Martini 🍸 GT2 8 Share this post Link to post Share on other sites
Re-Bugged 10152 Posted March 12, 2021 You’ve got to happy with that chassis now @Shodog, it’s a massive improvement to how it was 👍🏻 1 1 Share this post Link to post Share on other sites
Shodog 1835 Posted March 15, 2021 On 3/11/2021 at 9:51 PM, Re-Bugged said: You’ve got to happy with that chassis now @Shodog, it’s a massive improvement to how it was 👍🏻 chassis fits the body so much better. I’ll probably paint a new body for this car. I have to use some funky spacers to get the body to fit the old body holes. Would be nice to have a new body that fits it perfect 5 Share this post Link to post Share on other sites
ruebiracer 1046 Posted March 15, 2021 10 hours ago, Shodog said: chassis fits the body so much better. I’ll probably paint a new body for this car. I have to use some funky spacers to get the body to fit the old body holes. Would be nice to have a new body that fits it perfect Hi Shodog, what is wrong with the spacers, body is sitting perfectly? Great color and crazy wheels! Tamiya was so lazy to not do this mod by themselfs. Clever trick also with the propshaft. Probably quicker than shortening both outdrives like I did... Have fun, Matthias 1 Share this post Link to post Share on other sites
Scott_CT 30 Posted September 21, 2021 On 3/11/2021 at 12:15 AM, Shodog said: It’s a combo of clear red and gunmetal. How many coats of the Translucent Red did you use? Share this post Link to post Share on other sites
Shodog 1835 Posted September 21, 2021 33 minutes ago, Scott_CT said: How many coats of the Translucent Red did you use? I did very light coats until the can was done. The paint with run if sprayed too thick. Paint the hard corners and creases first. Leave the big flat parts for last Share this post Link to post Share on other sites
alvinlwh 5895 Posted September 21, 2021 3 hours ago, Scott_CT said: How many coats of the Translucent Red did you use? 2 hours ago, Shodog said: I did very light coats until the can was done. The paint with run if sprayed too thick. Paint the hard corners and creases first. Leave the big flat parts for last If you can use an airbrush, it will give you far better control and protection again paint running as well as makes getting into corners easier. It is possible to decant the PS paint out of the spray cans to be airbrushed - OR - use Vallejo acrylics (or similar). Share this post Link to post Share on other sites
Shodog 1835 Posted September 22, 2021 It’s not too hard to get a good even coat with a rattle can. However before screwing up an expensive 934 body I practiced the paint combo on a cheaper HPI body. 1 Share this post Link to post Share on other sites
