Hi,
I’m new to the whole RC car thing. I have just managed to prise my Dads Tamiya Fox 1980’s original off him and have been playing with it with my 10 year old son.
A few weeks back we changed the motor as the old one was done, got some new batteries, lubricated the servo etc. It’s been running fine for about 3 weeks and then the other day it started making a grinding noise from the gear box.
I took the gearbox and drive shags apart and put it back together re-lubricating all the cogs and it worked for about 10 minutes and now seems to have lost drive almost completely.
The right wheel (when looking from the back) spins and turns the motor however the left one spins independently and you can literally flick it and it’ll keep spinning. I’ve double checked all the joints and the axels going into the gear box and they seem fine so I think it is something to do with the rear axle.
So my question is, can I use novafox parts to update my fox? Will this work and what do I need? I’ve found loads of parts but not sure I can find everything I need.
Or are there other parts I could use that would do the same job?
Any help is really much appreciated
Check the motor pinion grub screw is tight onto the motor shaft , and that it is tightened onto the flat of the shaft . These are a common cause of loss of traction but are an easy fix
I just went thru something similar. In my case it was the rear wheel adapters that broke. But during the inspection I notice my gearbox was cracked.
So replaced my vintage Fox cases with NovaFox ones and it has been great. One thing is if you switch cases... you use e clips instead of c clips. That is the one catch I know about... to my knowledge the rest of the part are interchangeable.
If it is the axle... i assume you would need dogbones, inner and outer cups. Supposedly the vintage axles need to be greased now and again otherwise they wear... this is going by what i have read... not experience.
