i need the resistor metal cover and if possible long resistor wires and long yellow and green motor wires plus the msc to servo connector rod for a hornet
these are needed to restore a original hornet
Yeah that will do perfect:) i dont expect to get a original part tbh as long as I can reinstall a msc i will be happy.
Let me know how much:D
You can have it. None of my kits have msc's in them any more so it needs a new home. Its got some patina to it but ive just given it a rub down with some autosol and it doesnt look too bad now. Pm me your address and I will try and post it today.
I've got some parts here . I have black-boarded MSC with wiper arm and , worn at resistor end,  resistor leads brown and blue - blue is piggy backed so I think it was from a Monster Beetle or Brat , no BEC lead or Yellow & Green motor wires soldered on , but I'm sure I've got new BEC leads you can solder in , not got Y&G motor wires tho'   . I have a few white resistor mount boards and some metal resistor cages including the one for the Hornet  , (but you might have already sorted that ? ) I have the switch rod and a resistor , but the resistor is a later type with thinner connector tabs than the resistor wires spades but you can change the wire ends to fit the resistor ?  . Any good ?
18 hours ago, KEV THE REV said:
Did you get the parts you needed ?
i managed to get the cage form "Superluminal"
witch turned up today and a msc of ebay
but i still need the con bar and saver from the msc to the servo
2 hours ago, KEV THE REV said:
I've got the connector bar , and do you mean the servo horn for the Speedo servo ? This will depend on you servo brand
great if you want to sell it i'll have it please but tbh i have not yet give it a thought for the receiver and servo but if i remember there is a acoms in the steering
On 3/18/2021 at 9:11 PM, KEV THE REV said:
So are you also needing the steering servo saver , or do you have that , and just need the MSC rod ?
i am just waiting for the msc to turn up up plus the the a part tree to turn up i will let you know when they arrive
