Sign in to follow this
Matty36
New season, losi xxx4
As it's nearly the start of the offroad outdoor season, I have decided to dust off and rebuild my old buggy. I had converted it to a rally car during lockdown 2020, now I have decided to rebuild it to its 2003 spec apart from some changes, which are;
Hobao 12mm big bore shocks, for adjustability and the same springs as my 2wd buggys.
Wing is now screwed on instead of clips.
Rear pin drive is now 12mm hex, again to keep it the same as the 2wd buggys.
Front is still on 10mm hex, but I have a few sets of wheels with tyres, so no big issue for now.
The steering servo is now on the opposite side to help weigh more on the battery side.
I was going to change the driveshafts for the losi 22-4 as it uses 12mm hex all round, but for some reason losi used weird driveshafts on the xxx4 and they are twice as thick as 2wd ones, so anything else is too loose in the diff outdrives. I am just waiting on some more steel outdrives, as it uses steel on the front and I want them on the rear as well so I can fit brushless. The bodyshell will need to be ordered, but I have the original one.
