BJoe76 571 Posted April 4, 2021 Now that I’ve had a chance to open the WW2 kit and look over things. I have a question about the wheels. Is it possible to use the WW2 wheels on the Lunchbox? Looks like the offset is the same, but the rear wheel hex arrangement is different. Do the hex adapters I’ve seen in line allow for the use of these wheels on my Lunchbox? Oh, is there a source for foams I can use in these wheels too? Share this post Link to post Share on other sites
toyolien 4681 Posted April 4, 2021 There was a thread about this I was reading the other day: Share this post Link to post Share on other sites
KEV THE REV 2319 Posted April 4, 2021 They will fit with hex adapters . I have WW2 wheels on one of my LB's , no problem Share this post Link to post Share on other sites
topforcein 1764 Posted April 5, 2021 i put a set on my lunch box a fair few years back they go straight on even with the alloy wheel hubs that i have on mine Share this post Link to post Share on other sites
BJoe76 571 Posted April 5, 2021 1 hour ago, topforcein said: i put a set on my lunch box a fair few years back they go straight on even with the alloy wheel hubs that i have on mine Which adapters did you use? Share this post Link to post Share on other sites
topforcein 1764 Posted April 6, 2021 i just swop'd over the stock rear hubs for alloy ones of the same design as i was sick of them cracking the fronts are just ball race fitted Share this post Link to post Share on other sites
J@mes 2326 Posted April 6, 2021 Frog hex adapters and WW2 wheels on the LB no problem 😉 Widens the rear nicely 👍 1 Share this post Link to post Share on other sites
KEV THE REV 2319 Posted April 6, 2021 That's the ones Share this post Link to post Share on other sites
KEV THE REV 2319 Posted April 6, 2021 1 hour ago, J@mes said: Frog hex adapters and WW2 wheels on the LB no problem 😉 Widens the rear nicely 👍 I widened the rear even more by redrilling the pin hole nearer to the nut thread and using barrell nuts to match the Ultima custom front beam 1 Share this post Link to post Share on other sites
