Luckyluke420
Fs12 tg10 mk1 motor issues
I decided to pull out of storage after 15+ years my tamiya tg10 mk1 with fs12 engine. It's the 1/8 scale 2000 Subaru wrc
Engine was siezed from old nitro oil goop. I cleaned it up. Freed it. Cleaned carb. Got it to work just fine...everything works fine but after about 3min of driving once it gets hot it instantly shuts off and won't restart until it's cooled. Tried leaning and richen mix. Carb has 1 screw and 1 idle opening screw. I replaced lines and clamps.  I replaced glow plugs and tried different heat types. The engine doesn't sputter down it just turns off as if I put my finger on carb opening. Temp gun shows 200f to 220f everytime it shuts off. Engine hasn't seen a full gallon since I buy it 15+ years ago and played recently.
Any ideas? Thanks
Sounds like a classic case of worn out piston/liner. While it won’t change the issue your having did you completely strip and rebuild the engine or just throw oil at it and force it?
200-210 is not super hot, in fact it’s a good temp, but where and how are you measuring it?
Measuring using a fluke infrared thermometer.  Red dot the center by glow plug. I know 200 to 210 is not hot at all. Its just the temp I see It gets to before it dies and won't start. As for cleaning I soaked it in rubbing alcohol then I heated it up to get the oil to be more gooey. Sad to hear it's the liner and piston. Car didn't even see 1 gallon of nitro through it.
Wow fluke, that should be good :-).
I would strip and rebuild, I would expect (not guarantee) a lot of rust in the rear bearings and the piston pin to be seized/sticky on the con rod. I would be surprised but not shocked if you could see or feel any roughness on the liner but I would look for it and also look at the piston body for damage.
once it’s all clean reassemble... now there is a chance that reassembly will move the position of the piston/liner and provide a bit more compression for a short while, maybe :-)
I will take it apart maybe this weekend and let you know.
Any ideas if other engines would fit this tamiya? I have a trx15 from a traxxess but the output shaft is short. Unable to transfer the flywheel, clutch, and gear.
Those engines did not last very long even when new , look out for an os cvr12 engine or fantom fs12
