 I think so...? They still take 6mm bearings, and are the same length. But the re-re uses screw-in pins to hold on the drive washers, like a modern buggy, instead of the press-fit ones on the originals. So if you get the axles, you need to get the drive washers and screw pins from the re-re as well.
24 minutes ago, mongoose1983 said:
Thanks Mark. Other than that, I doubt the new differential would fit in any way inside the original gearbox, perhaps the gears don't mesh?
No, but they did sell an entire retrofit gearbox just for the original cars. I don't know how available it is now, though.
