Evening.
Looking to build the mini cvas and attach to my tt01 built tomorrow. Might anyone be able to advise on the best method of attaching them? The kit includes, and the instructions offer both 5mm ball connectors or self tapper with ball collars. I'm not sure which is best for this application. The stock pogo sticks are attached with a self tapper arrangement so I'm leaning towards replicating this with the self tapper and ball collar.
2021-04-29_07-25-49
either is fine ,ball connectors are obviously quicker to get on and off plus winding ab screw in and out will lessen the grip over time but! the ball collers are a nicer fitment.
  • 4 weeks later...
Think about maintenance: every time you will want to do maintenance on the lower arms or the shocks themselves you have to undo the shocks.
Ball studs are difficult to remove as you need a 5.5mm flat wrench and it is tedious. Ball collars are awesome because you can simply remove the screw with a screwdriver.
Then some folks simply twist the shock off the ball and leave the ball on the car; I personally don't do that anymore.
