Would be nice if we could add a kit number and a small descriptio for any item that falls into these "misc" categories : for instance in the main page It would be nice to get this information for the last reviews.
Anyway to get categorized list of all articles, ordered by month. My point here is that have here some "professional journalists" and all these reviews could make a nice monthly magazine.
Raoul
PS : sorry of the english, I am not familiar enough with the publishing sector.
58298 Tamiya Enzo Ferrari TB-01 chassis.
Ferrari's latest sports car flagship, which appeared on so many magazine covers and gathered unprecedented attention, the Enzo Ferrari now comes replicated as an R/C car model. The realistically replicated body as been combined with the 4WD high performance TB-01 chassis to make you feel like you're driving the actual car.
Spec:)
Chassis Type: TB-01
Scale: 1/10
Total length: 457mm
Total width: 202mm
Clearance: 7mm
Weight Fully-Equipped: 1,650g (Measurement includes TP-S3003 servo, CPR Unit and RC2400SP Battery with RS-540 motor)
Wheelbase: 257mm
Tread F/R: 159/157mm
Chassis Material: ABS
Chassis Shape: Bathtube Frame
Steering Tie Rod: 3 part
Suspension: Front and Rear Double Wishbone
Caster Angle-F/R: 10deg/0deg
Camber Angle-F/R: adjustable
Toe Angle-F/R: adjustable/2deg
Damper: F/R CVAMiniII
Drive train: longitudinally mounted motor/shaft driven 4WD
Gear Ratio: 7.94:1 (9.91-5.72)
Diff. gear system: F/R 3-Bevel
Speed Controller: 3-steps Mechanical Speed Controller
Tire Width: F/R both 27mm
Tire Diameter: F/R both 65mm Tread Pattern: F/R Racing Radials.
Motor: RS-540 Type Motor included
Thanx
Jimbo
