Wooster 30 Posted June 7, 2021 Hi all - before I glue the tyres on to my Hotshot Re Re - is it worth holding fire and ordering some foam inserts? If so - which ones should I go for? Share this post Link to post Share on other sites
Frog Jumper 3660 Posted June 7, 2021 Go to a fabric store (like JoAnn’s in the US) and buy some upholstery foam. I bought a 24”x24”x2” square for about $10 a few months back. Do some math and get out a razor and cut some strips. Roll the strips into a donut and insert into your tires. Don’t like them? Take them out. Minimal loss and you can use the remaining foam as a cushion on your workbench chair. Terry 1 Share this post Link to post Share on other sites
Frog Jumper 3660 Posted June 7, 2021 And use silicone caulk (clear) to glue your tires. It’s works as well as glue, but can be cleaned off. 3 2 Share this post Link to post Share on other sites
ruebiracer 1046 Posted June 8, 2021 Philosophical question! Never drove the pin spike with inserts, but Avante uses foams in them. Also new VQS kit contains foams (surprisingly, Vanquish didn´t have them). Tamiya recommends 51448 for the wider rears. I do have to check, if there´s another one for the front, or if you have to cut them... Kind regards, Matthias 1 Share this post Link to post Share on other sites
Wooster 30 Posted June 8, 2021 20 hours ago, Frog Jumper said: And use silicone caulk (clear) to glue your tires. It’s works as well as glue, but can be cleaned off. Good tip! Thanks Share this post Link to post Share on other sites
KEV THE REV 2319 Posted June 8, 2021 I wouldn't think that HS tyres would flex enough to need foams ? Share this post Link to post Share on other sites
Mrowka 494 Posted June 8, 2021 FWIW, i keep ripping tires off the rims when I glue using bathroom silicone. That may just be a sign that I am doing it wrong. Share this post Link to post Share on other sites
Frog Jumper 3660 Posted June 8, 2021 1 hour ago, Mrowka said: FWIW, i keep ripping tires off the rims when I glue using bathroom silicone. That may just be a sign that I am doing it wrong. Honestly, I'm the last person that should be giving advice on how to affix tires to the rims. I don't do use caulk or glue or anything... Terry Share this post Link to post Share on other sites
Wooster 30 Posted June 8, 2021 I've decided not to foam. There's not a lot of space in the HS tyres and, as you say @kevtherev - they are pretty firm. I only mentioned it as Foams in my Blitzer Beetle have made a real difference and I would foam my Lunchbox wheels if I hadn't glued em already... Share this post Link to post Share on other sites
KEV THE REV 2319 Posted June 9, 2021 22 hours ago, Wooster said: I've decided not to foam. There's not a lot of space in the HS tyres and, as you say @kevtherev - they are pretty firm. I only mentioned it as Foams in my Blitzer Beetle have made a real difference and I would foam my Lunchbox wheels if I hadn't glued em already... I would agree with the BB tyres and I've foamed 2 of my LB runners Share this post Link to post Share on other sites
Re-Bugged 10141 Posted June 9, 2021 On 6/8/2021 at 4:08 AM, Frog Jumper said: And use silicone caulk (clear) to glue your tires. It’s works as well as glue, but can be cleaned off. I’ve only ever used Clear Silicone (Natural Cure) for my tyres, on & off road, with no problems. It can be a bit messy with first wheel but the 4th wheel is usually pretty good. A drop of dishwashing liquid in some water is good for cleaning up. 1 Share this post Link to post Share on other sites
Frog Jumper 3660 Posted June 10, 2021 YMMV, but I intend to put foams in my Fire Dragon build, when I get to it. I’ll likely have to make own, since the Terra Scorcher wheels are an odd/vintage size. I’m concerns about cracking the rims with no “cushion”. I don’t intend to glue/caulk the tires, so any kind of pneumatic cushioning from the tire itself will be lost. Terry Share this post Link to post Share on other sites
Mrowka 494 Posted June 10, 2021 23 hours ago, Re-Bugged said: I’ve only ever used Clear Silicone (Natural Cure) for my tyres, on & off road, with no problems. How do you do this? My brushless buggies rip the tires from the rims. Share this post Link to post Share on other sites
Re-Bugged 10141 Posted June 11, 2021 3 hours ago, Mrowka said: How do you do this? My brushless buggies rip the tires from the rims. I put the tyre onto the wheel, push the inside bead to towards the centre of the rim. Then squirt the Silicone around the inside edge of the wheel rim, sometimes straight from the nozzle, or sometimes using a toothpick or cocktail stick to apply it. Then seat the tyre bead into its proper position. Then repeat on the other side of the wheel & tyre. Wipe off excess silicone with a damp soapy rag. Leave them overnight before running them. Hope that makes sense. I use silicone as it’s more readily available to me and have used the stuff for years when I was in construction. 1 Share this post Link to post Share on other sites
KEV THE REV 2319 Posted June 11, 2021 That's how I do it , except I use trade wipes to clean up , but I remove most of the excess dry as much as possible first , they remove silicone, wet paint etc . I am also in the trade. 1 Share this post Link to post Share on other sites
Wooster 30 Posted June 11, 2021 10 hours ago, KEV THE REV said: That's how I do it , except I use trade wipes to clean up , but I remove most of the excess dry as much as possible first , they remove silicone, wet paint etc . I am also in the trade. Hey Kev. I’m all set to silicone my tyres on but just wanted to check what you meant by ‘I remove most of the excess dry as much as possible first’? Do you mean you remove any excess when it’s still wet - or let it dry and then remove it? Also - when I’ve glued in the past - I just did a few spots round each rim. Would you recommend a continuous bead with silicone? ...Blimey, the things I talk about on a Friday night 😅 Share this post Link to post Share on other sites
KEV THE REV 2319 Posted June 11, 2021 By 'dry' I mean not with a soapy cloth - the silicone is fresh wet , not left to dry . As I use silicone a lot , I swipe ( that is swipe in a flick motion toward the rim rather than 'wipeing' straight along the tyres bead ) off the excess with a dry finger and keep wiping my finger on a cloth to remove the excess then carry on . I wipe away from the tyre , then clean off the residue with the wet wipe cloth - keep everything to minimum , you don't need to go mad with it a small continuous bead is fine , use too much and it will just ooze out . I load the tyre on to the rim and push the beads to the middle of the rim . I gun the silicone then 'hop' the tyre bead over the silicone with a finger grip and into the rim bead so it kind of lands on top of the silicone - hence not to much is needed Share this post Link to post Share on other sites
Mrowka 494 Posted June 11, 2021 Ok, that's more or less how i do it. It works for me on tires on lower-powered buggies but strong brushless motors, not so much. Share this post Link to post Share on other sites
