gizard 133 Posted June 8, 2021 So from the Manual I deduce the following: Step 1 BA17 1280x8 Metal - Suspension link mounts external Step 6 BA19 1050x6 Metal - Axle (2 are external facing) Step 6 BA18 1050x2 Ball Bearing - Axle interior Step 7 BA18 1050x2 Ball Bearing - Axle input shaft interior Step 7 BA19 1050x2 Metal - Axle input shaft external Step 10 BA19 1050x2 Metal - Outdrive inner Step 11 BA19 1050x2 Metal - Outdrive inner Step 23 BD8 1510x1 Ball Bearing - plantery gear Step 24 BD7 2415x2 Ball Bearing - gearbox Step 24 BA18 1050x2 Ball Bearing - gearbox Step 24 BD9 850x1 Ball Bearing - gearbox Step 32 BA19 1050x4 Metal - Outdrive outer So therefore need to order (to replace the metal bushings): 8x 1280 rubber shielded 2+2+2+2+4x 1050 Rubber Shielded 4x 1050 Metal Shielded Am I correct ??? -( I have not yet received the kit to double check). Share this post Link to post Share on other sites
Badcrumble 4204 Posted June 8, 2021 I'm not sure your total is correct but apologies if I have misunderstood. Here's the link to the RC Bearings listing for the CR-01 https://www.rcbearings.co.uk/index.php?route=product/product&product_id=135 He lists 40 in total but you list 34? I have totalled up the bearings from the parts bag pages of the manual and also get to 40 in total. I've not reviewed to see what the split between metal and rubber shielded might need to be. 1 Share this post Link to post Share on other sites
gizard 133 Posted June 9, 2021 (edited) Ahh thanks - missed out Step 22 by mistake - which are already proper bearings so not required to be upgraded from bushings 850x6: Step 1 BA17 1280x8 Metal - Suspension link mounts external Step 6 BA19 1050x6 Metal - Axle (2 are external facing) Step 6 BA18 1050x2 Ball Bearing - Axle interior Step 7 BA18 1050x2 Ball Bearing - Axle input shaft interior Step 7 BA19 1050x2 Metal - Axle input shaft external Step 10 BA19 1050x2 Metal - Outdrive inner Step 11 BA19 1050x2 Metal - Outdrive inner Step 22 BD9 850x6 Ball Bearing - planetary gear Step 23 BD8 1510x1 Ball Bearing - planetary gear Step 24 BD7 2415x2 Ball Bearing - gearbox Step 24 BA18 1050x2 Ball Bearing - gearbox Step 24 BD9 850x1 Ball Bearing - gearbox Step 32 BA19 1050x4 Metal - Outdrive outer So my purchase list still stands 8x 1280 rubber shielded 2+2+2+2+4 = 12x1050 Rubber Shielded 4x 1050 Metal Shielded Edited June 9, 2021 by gizard correct maths! Share this post Link to post Share on other sites
