As I have to wait for some parts to be delivered for the Super Astute, I am devoting myself to another project:
TA-03F PRO David Jun
Although I had never own a TA-03 before I am torn between love and hate of this chassis. Last year I got this special edition from Japan for a good price, so I`ll have to give it a try.
The car is quite in good conditions, even if though it was used. Due to the FF-01 addiction during the last year, there had been no time to spend on this project. But I had used the meanwhile to get some Hop-Ups:
Now it is time to dissasemble the kit and clean everthing up. Since it`s going to be a runner I will make some modifications. First I will use gear diffs at the front and rear and Modul 0.6 instead of 0.4 also the torque splitter will be removed.
Regarding to the setup I will try to keep it very similar to my FF-01 setup, e.g. blue springs in the front, reds in the rear. But I don`t know what to do with the anti-roll bars... Do you have some recommendations? I want to mount them, just because they are neon color.
Back in the days we ran mainly TA03 on our schoolyard races. I never owned one, but I know the others had problems of understeer. Especially with the F setups.
I have a TA-03R-TRF also, but sits on the shelf. Like this unusal 4WD layout, so I give it a try.
Already worked a little bit on the TA-03F. The previous owner replaced the J5 part to aluminium posts. They were blue anodized and unfortunately not in the Tamiya blue. So I decided to polish it, think this will fit better to the other silver aluminium parts.
Small parts, but lot of work...
The David Jun is euipped with a lot of aluminium parts. Originally it comes with CVDs in the front only, but I have another set in my FF-01 box, so why not have CVDs in the rear too?
Like that too. Like the predecessor of the XV-01.
Was a very radical design change in comparison to the TA01/02
Definitely in my list to have.
Nice that it came with the front knuckles (53325) and also the Alu steering set (53326), as these were not included in the original David Jun version of the kit, and both command high prices if you can find them, especially the knuckles. The Carbon stablilizer part at the rear is also an addition - didn’t come with the DJ, but was included (like the steering arms) with the two (R and RS) TRF versions that followed (58227, 58243). Such a quirky design, worth having just for that. I used to have one, now I’ve just got the TA03R-TRF ready to build one of these days 👍
Thanks for the informations! Did not have known that these parts are rare, as I´ve got a second pair with it :D
After everything has been cleaned, it's time for assembly.
First, the carbon deck was sanded and sealed and a protective film was applied:
So everything is prepared and the building started. First of all I am going to use gear diffs at front and rear:
But then the problems started. The front gear box is broken on several positions. Luckily I will get new black A-Parts to fix this issue.
So I decided to start with the rear. But unfortunately the rear gear box is damaged too. :( Black B-Parts are sold out everywhere, so I will try to fix it, as there are no heavy loads at the gear cover.
But this arrested me to  continue the build, so I started to paint the body. I am sure you can guess what body I have choosen.
Today some brand new A-parts arrived and I could`nt resist to continue the build. I just love these little tuning parts, like the carbon axle in the front. Also mounted an adjustable upper arm set, as well as Modul 0.6 gears.
Finally the front is done. Looks really solid, but I am just wondering how I could control of the motor heat. :unsure:
But no worry, Tamiya takes care of this problem, by including an air channel for cooling. :P
Nice car! I too have a love/hate relationship with the TA03(F). My first TA03F was a drift car for me, about 15 years ago, when I didn't have the money (or knowledge) to maintain it well. It would always break and wasn't very good to drive. I got rid of it in favor of a TB02 which was much better at the time and have hated the TA03F since. But I absolutely love all other cars in the TA0x series and would one day love to have a TA03 in full Tech Racing options. Maybe this thread will convince me to finally get another. :D
They make a metal motor plate that sits between the gearbox and motor, it does help.
#53357
#53357
Tamiya 53357 is already installed. But this aluminium motor plate sits in the middle, so no Chance to dissipate the heat.
it should assist in heat transfer directly to the gearbox though.  especially if you have the aluminum motor cover too.
I have managed to get new black B-parts. :D
So I spent some time completing the rear gear box, also fitted the dampers and anti-roll-bars.
What a difference!
Looks great 👍the 03 is a fantastic looking chassis. The black gearcases look way better in black.
I have a trf R which I've spent a fortune on 😕
Are you going for the full hop up build?
Yes I am going for full option, as it will be a runner I only change some parts for better handling/easier maintenance.
Let's complete the build...
First of all, the carbon deck. This is what a TA-03F should look like:
As there are some red accents (Super Stock TZ, ESC) I decided to add a little bit more:
The next steps took a lot of time, especially the electronics. But Tamiya was far ahead of the times with the carbon battery mount, because my shortys are fitting perfectly!
And here it is:
I have also solved the heat sinking problem, by adding a fan.
Now it is time for working on the body...
What ESC are you using? Doesn't look like a HW 1080.
The red servo stays are a nice touch! Pretty rare parts, right?
Yes the Red servo stays are quite rare.
I am going to use a Robitronic Cube 2, as it is equipped with a lipo cut off.
Cool, I didn't know that ESC. Looks nice. Similar to the Tekin RS Pro, which I've been using for my M-chassis since it has a lipo cutoff and is programmable.
Let`s go on with the build... After the painting of the body, there were still many parts for masking:
But I like the result:
After spending a lot of time in bodywork, I had to realize that the body didn't fit, because of the front motor of the TA-03F. I`ve not checked it before, because the TA-03 was disassemble at that time.
I was really disappointed and and I wonder how I should explain to my wife, that I will need another body? No problem my wife said "Don`t worry just buy another chassis for the Mercedes body and another body for the TA-03". I had never expected that kind of answer! :blink:
But first I worked on the chassis a bit more. Managed to fit double cardans at the front. Therefore the front knuckles had been changed to plastic ones, to fit the new bearings in. Not much space, but it works real smooth und no loss of steering angle.
As time is rare and I don`t want to do another body yet, I fall back on a body in storage. Fits very good and matches to the Primera:
Both chassis will go out for a track day tomorrow. Can`t wait to see how it performs!
Pretty well, I guess ;)
