3 hours ago, Raman36 said:
Just watched the Instagram feed. So there are parts for mounting the battery sideways. He talks and shows the battery not fitting with the current body. However that battery is a full length LiPo. So a shorty LiPo will definitely fit sideways! ๐Ÿ˜‰
Thought as much
29 minutes ago, Demon Dave said:
Anyone else see Tamiya's latest Live Stream on YoutTube...
Now thatโ€™s what Iโ€™m taking about, the shell looks much better without the fenders imo
And paint other than box art
I was thinking of buying a Team Bluegroove or Sabula Tech repop body for this car, but the stock shell looks great the way this is painted.
Also peep the Big Bore Shocks on the rear.
Looks like some more hops ups coming:
Alu Crank Arm
Alu Rear SuspensionMount
Alu Rocker Arms
Alu Steering Arms
Alu Steering Bridge
Alu Stabiliser Set
Alu Crank Arm
Alu Rocker Arms
Alu Steering Arms
Alu Steering Bridge
Alu Stabiliser Set
Yes, confirmed in June and July. So far:
Hop-Ups:
22028 TD4 Assembly Universal Shafts (2 Pcs.)
22029 TD4 Differential Nut and Screw Set
22030 TD4 Aluminum Servo Stays
22031 TD4 Slipper Clutch Set
22032 TD4 Aluminum Steering Bridge
22033 TD4 Aluminum Steering Arms
22034 TD4 Aluminum Crank Arm
22036 TD4 Aluminum Rocker Arms
22037 TD4 Stabilizer Set
22038 TD4 Aluminum Rear Suspension Mount
47464 TD4 Titanium Screw Set
Regular spare parts:
51674 TD4 C-Parts (Uprights) (2 Pcs.)
51675 TD4 D-Parts (Suspension Arms) (2 Pcs.)
51676 Super Avante Body Parts Set
ย
Photos are out for most of them:
ย
ย
ย
219163491_3959734110820162_8893085155282568478_n.jpg219183662_3959734017486838_5551203305227814468_n.jpg
219202763_3959733920820181_1278491482799853116_n.jpg219869813_3959734014153505_5705492128266466165_n.jpg
236139984_4022287231231516_8104294885853071215_n.jpg236557289_4022287261231513_2054528202805193098_n.jpg236633337_4022287254564847_2964414931182526167_n.jpg
240886843_4077419015718337_2188067168774668377_n.jpg240914574_4077596115700627_607916242229257150_n.jpg
225748901_3984989921627914_2732117156900938002_n.jpg226038476_3984994871627419_6057606964760606126_n.jpg
  • Thanks 2
4 hours ago, toyolien said:
That's gonna be one heck of an expensive car with all those 'hop ups'!
That's exactly the reason I'll stick with plastic kit parts. I'm kinda deep into an LC EMB-1, and myย only alloy parts are the front knuckles and c-hubs. The logic with the EMB-1 crowd is that numerous alloy hop-ups will transfer crash trauma elsewhere, like A-arms or suspension blocks, necessitating deeper, more expensive repairs when mishaps occur. And they will occur. At least when I'm holding the controller.
I'm just suprised that tamiya haven't produced a set of alloy shocks like the hi-caps or vqs type! or do any of them fit?
According to the Tamiya USA live stream the DF03 alloy shocks are the reccomended hop-up. But that means that most Tamiya buggy shocks should work it seems.
The MS painted one on the image here has TRF Big Bores on it.
ย
Itโ€™s looksย awesome- seems to run well from the footage,ย canโ€™t wait to get it. Not sure what Iโ€™ll do with the paint scheme and fenders but there is a load of things possible.
ย
Probably worth getting this and Maybeย upgrading the rear wishboneย mounting balls to the hardened type. Less chance of the wishbonesย popping off in a shunt.
Still showing 21st October as expected and early November on others. Was checking this myself. Iโ€™d reckon on early November hopefully and not like the thunder dragon which appeared 6 months later!!
Itโ€™s probably sitting inside a gigantic container in one of your ports. This is the case for the US. There are 73 ships waiting at port outside ofย Los Angeles waiting to unload their containers. Lots of Tamiya product in those containersย
  • Sad 1
So far the major ports are okay here, the issues are delays leaving the port though so it will get worse as container traffic picks up toward the end of the yearย
I might get one, paint it black instead of blue, and call it a Tamiya Wasp. Quick photo-edit below:
Thank you Tamiya for going back to the fantastic box art, instead of the insipid photos of newer models!
Brilliant idea!ย  Or call it the Ultra Hornetimage.jpeg.22980965e2b6e5ea066f3b46426c2696.jpeg
Seriously why doesn't Tamiya ever come up with these ideas. That looks so much better imo. ๐Ÿ‘
James.
  • 3 months later...
Has anyone builtย this and found a rear body fit issue? I'm an experienced modeler. I built it exactly to spec (and double-checked it),ย and the body simply does not fit the rear mounting posts. It's jammed down and crooked by the spur gear housing.
I found left over 6mm parts that served as perfect spacers. The posts are no longer "keyed" in their positions, but I positioned them by eye and they're firm - not going anywhere. I swapped the 3m x 12mm screws withย spare 3m x 18mm screws that mounted them perfectly. The body now fits perfectly.
I'm just surprised, both that a Tamiya kit would have such an issue and thatย I've not seen a word about this.
My body, cut to the trim lines, fit perfectly with the stock mounts. No adjustment needed.
Any chance of some pics of yours?
    • IXLR8  »  Clappy75
      Hi Jon,
      In the linked image, I've simply moved the bar forward until it is centered directly over the rear shock tower (approx. 10.72mm) and kept the same height. ย Is this what you had in mind?
      https://flic.kr/p/2roEkj2
      Dougย
      ย
      ย
      · 0 replies
    • WhteRbt
      Checking out this status thingโ€ฆย ย And now with a beautiful avatar! ๐Ÿ˜‚
      · 0 replies
      · 0 replies
      Hello
      Hope you are well
      Thank you for your help
      Kind regards
      Jack
      · 0 replies
    • seoondaddy
      Seo-onDaddy - YouTube
      · 0 replies
