Mechanic AH
The Tamiya Super Avante #58696 Information and Pictures
7 minutes ago, joeling said:
Are you saying this white wheel can be dyed ? Thanks !
Yup
these are the standard white star dish wheels that I used Rit dye on:
IMG_1829
You pop the dye in a bowl of hot water, mix it up, add the wheels and leave them to soak for a few minutes and then take them out and rinse in clean water.
This is the stuff I used:
https://www.ritdye.com/products/super-pink/
IMG_6633.jpg?width=1920&height=1080&fit=
IMG_6637.jpg?width=1920&height=1080&fit=
Overshot the color :blink:. Now it's the color of a dragon fruit.
Hmmm.
So I've got no actual idea if this will work, but I wonder if bleaching them might bring the colour back a few shades?
The way I see it is that it's dyed, not impregnated pigment, so it should act the same as if it were a fabric (polyester is largely similar to acrylic, and it would work on a pair of polyester undies)
Might be worth a try on a spare parts tree first?
1960’s Lotus homage theme
Edited by Busdriver
  • Like 13
Few interesting pics from Modeler Oyaji ‘s latest vid on the TD4, notably aftermarket db02/td4 steel counter gears, not the best screen shot, but brand appear to be Super Rajikon
45443104-7A28-4813-B3BA-1425849903A0.md.
https://super-rc.co.jp/rc/category/?pcm_cd=01-04-01-66&sort=nw&scend=1&offset=0
Then at the Tamiya Race track, he spys this Avante 2021, which I actually quite like.
5F2FA267-F6F8-442D-BE08-4DD194C28BF3.md.
03CC5F80-A86B-4094-86A0-009A66623DE2.md.
vid is here:
What do you guys think about 25t pinion with the 79t slipper spur ? That’s a ratio of like 8.216
I’ve a 26 in there, FDR of 7.9 with a target of 8 for my 10.5t motor
1 hour ago, Alangt4 said:
Yeah that’s same FDR as mine and plenty fast for me.
Which motor you running ?
Mine is still sitting on the shelf but I have a Tamiya 10.5T with 30/79 gearing. Estimated top speed 51km/h gearing 6.85.
Could anyone with a runner comment on how noisy they are compared to your other machines? Trying to decide between this and a DB-02. I was hoping the new gearcase on the TD4 might be a bit quieter than some, even if not as quiet as the DB-02 belt drive.
It’s about the same as my other cars. Do you mean the DB02 Leonis? I thought that car was discontinued. And shaft drive.
Much quieter than the older buggies at least- haven’t run db02 though. The finer pitch of the gears is noticeable. Plus if running brushless it helps.
DB-02 isn’t great for parts which is a problem if you run it a lot.
edit: it’s just a slight bit quieter than the top force on checking it…
Finished! Again, I added the TT02B/DT03 dampers, slipper and front cvds.
  • Like 15
I like your colour scheme, what colours did you use?
Thank you! This is PS-16 Metallic Blue and PS-23 Gun Metal. I'm not a big fan of the yellow but I wanted to try to keep some Avante colors. :)
A friend of mine mentioned that he saw online that someone added an additional support bearing at the bevel gears (that transfer power to the central shaft). The problem is he can't remember where. I'm wondering if anyone here has come across this?
I'm trying to find out more about how it was done.
My TD4 is less noisy than my old Leonis DB02.
The DB02 is shaft drive and quite noisy tbh. The DB01 is a super silent belt system. 👍
James.
James.
Ahh yes yes. I had the models wrong. It's the DB01 (Durga) I was thinking of. They're very quiet in the videos etc.
37 minutes ago, Boomerang89 said:
Seems McLaren got inspired by the Super Avante. Wheel fenders!
Nice color scheme as well btw.
Digs out fenders from the back of the cupboard…….
