Posted (edited)
With deepest sympathy.
Sending you our thoughts and prayers.
Is that a grub screw on the handle? If so are there replacement tips for these? Could be a ressurection!!
Edited by Superluminal
Thank you, it's been a tough day :unsure:
The tip is replaceable, but I can't find much on 3Racing screwdrivers.
At one point I did have an EDS 4.0 and, whilst the diameter was the same, the tip was a completely different profile and useless on Tamiya screws.
I have a lot of JIS bits and a couple of Tamiya drivers somewhere, will dig them out when I'm ready to start assembling again...
I too would be saddened if this happened to me, but just remember everything has a use….
It can be used to clean dirt / mud / poo out the bottom if your shoes after you’ve been outside :lol: i have an old dedicated screwdriver just for this!
I know, it's just that this one got used for everything else - my poo-pick candidates are numerous :lol:
Let this be a lesson - when you buy a screwdriver with a replaceable tip, buy a replacement tip at the same time! That's what I did with my EDS JIS screwdriver (which fits fine in tamiya screws - though mine is a 5.8mm and not 4mm)
I'm sure you'll be able to find a replacement tip somewhere, even if it's a different brand.
It wasn't until years later I realised what a unicorn a cheap screwdriver which did Tamiya 3mm screws was - by then it was too late.
I tried EDS as a spare, but the point profile was all wrong - just ordered a couple of ArrowMax from eBay to see if they're any better - Don't actually need it exclusively for Tamiya screws so much now, but it was just the right size for most screws around the house!
This is part of the reason why I have RC tools, car tools, and household tools, with clear limits placed on where each can be used.
Sorry for your loss...
@markbt73 the annoying thing is I was loosening (or aiming to) a self tapper in a UPVC window frame - pretty much the same circumstances as stripping down a Tamiya, but white plastic 😆
8 hours ago, djmcnz said:
Arrowmax replacement tips (https://www.smalladdictionsrc.com/) might well fit.
Also LRP replacement tips if you can find them, this is what I use and they're very good.
Cheers - I actually ordered some Arrowmax tips over the weekend, so fingers crossed...
https://www.ebay.co.uk/itm/203504102889
6 hours ago, c64orinoco said:
Never use your RC tools on anything else, the same rule applies for household tools. I keep mine strictly separated!
There's a few bits I don't cross borders with, but most of it (apart from the hedge cutter) is multi-hobby :lol:
