toyolien
#47455 Hi Cap Damper Lengths
I can't seem to find the eye to eye lengths of the new Hi Cap dampers. I bought a set for my Super Hotshot build but having just opened them, I'm thinking the fronts may be a little too short looking at the shock bodies. Does anyone know the eye to eye length to save me building these up to try?
I'm suspect I'd have been better off with the DF-03 dampers...
Thanks.
You’re talking about the VQS set???
Ill measure mine shortly and let you know. I did use internal spacers though…
Yep. The new VQS set. Thanks.
I'm hoping for 70-75mm front and 90-95mm rear.
As installed on my Dragon:
Front:  62mm. I think I used both spacers in each one.
Rear:  79mm. I don’t remember using spacers here, but I’m unsure.
The only reason I used VQS was the bling factor.  They were almost the same price as a set of 50519s and 50520s.  I almost bought those and painted them red but I figured I’d better get HiCaps while they were available.  I could always go back to 19s and 20s later…
I hope this helps (probably not)…
Thank you. That helps a lot. I suspect that these will be too short. Much appreciated though.
