Cynan 520 Posted August 6, 2021 Hi, I was just wondering if you will be stocking these, and if so, are we able to preorder? 22030 TD4 Aluminum Servo Stays 22028 TD4 Assembly Univ Shafts 22029 TD4 Diff Nut/Screw Set 22031 TD4 Slipper Clutch Set 47464 TD4 Titanium Screw Set Thanks Share this post Link to post Share on other sites
rwordenjr 1890 Posted August 6, 2021 5 hours ago, Cynan said: Hi, I was just wondering if you will be stocking these, and if so, are we able to preorder? 22030 TD4 Aluminum Servo Stays 22028 TD4 Assembly Univ Shafts 22029 TD4 Diff Nut/Screw Set 22031 TD4 Slipper Clutch Set 47464 TD4 Titanium Screw Set Thanks In the USA, tower hobbies. Outside of it, i'd check with tonytamiyaparts. Share this post Link to post Share on other sites
Cynan 520 Posted August 14, 2021 These are now listed, other than the Titanium Screw Set. Share this post Link to post Share on other sites
