museguy 39 Posted August 29, 2021 Hi All, I would like to purchase my first RC car, I would like to spend a total of around $300 (car and controller) for a car capable of starting to race on smooth surfaces and playing off-road. I am from the USA living in Mexico City during COVID-19. What do you think of the TT-02 for a first build ? Is the TT-02 better for a first build than the; FF-03 - Front Wheel Drive M-05 - Front Wheel Drive FF-03 - Front Wheel Drive M-03 - Front Wheel Drive I am from the USA living in Mexico during COVID-19, suggestions for vendors that ship to Mexico City ? Thank you ! An option (I welcome other suggestions): Flysky FS-GT5 $70 Battery and a charger $40 Steering Servo $25 Subaru Impreza 99 Mone Carlo TT-02 $170 TOTAL $305 Share this post Link to post Share on other sites
BuggyGuy 1106 Posted August 29, 2021 None of those are going to be that great off road unfortunately. Will you be racing at a club? 2 Share this post Link to post Share on other sites
SupraChrgd82 1425 Posted August 29, 2021 Visit your local hobby shop and ask what brands they stock parts for, then select one of those cars. The parts availability will reduce downtime if you break anything and make the hobby more enjoyable. 3 Share this post Link to post Share on other sites
alvinlwh 5895 Posted August 29, 2021 I noticed you did not include ball bearings in your option list, I think that should be essential, not an option. As for who ships to Mexico, the usual suspects from Japan do, like Plaza Japan or Hobby Search are the 2 that I use. Factor in maybe another USD 50 for shopping, best order all you need/can at once to minimise this. (don't make the mistake like me forgetting something and placing another order a few days later!) 3 Share this post Link to post Share on other sites
alvinlwh 5895 Posted August 29, 2021 2 hours ago, BuggyGuy said: None of those are going to be that great off road unfortunately. Will you be racing at a club? Can a TT02 be "hacked" into a rally car like the TT01? Not that I will recommend a first timer doing so though! 1 Share this post Link to post Share on other sites
NZJohn 78 Posted August 29, 2021 I think if you want to go off road you’ll need to go for a TT02-b. The off road version of this chassis. Plasma Edge. They can be picked up pretty cheaply. But start with your local hobby shop. Support local. And with luck, like I found, you’ll get great advice and great pricing. And get ball bearings 😜 1 Share this post Link to post Share on other sites
alvinlwh 5895 Posted August 29, 2021 Just want to add after looking at your list again, while the M-05 is not an off roader, the M-05Ra is a mild one. I had recently built one, but do not like it personally and adjusted it back to a regular on road M-05. https://tamiyabase.com/chassis/128-m-05ra#models-with-m-05ra-chassis 1 Share this post Link to post Share on other sites
TurnipJF 9192 Posted August 30, 2021 15 hours ago, alvinlwh said: Can a TT02 be "hacked" into a rally car like the TT01? Not that I will recommend a first timer doing so though! The '02 can be built with high (rally) or standard (on-road) ground clearance with no hacking required. The manual gives clear beginner-friendly instructions on how to do so. 1 1 Share this post Link to post Share on other sites
alvinlwh 5895 Posted August 30, 2021 11 minutes ago, TurnipJF said: The '02 can be built with high (rally) or standard (on-road) ground clearance with no hacking required. The manual gives clear beginner-friendly instructions on how to do so. Ah, quite like a M-05Ra then. Thanks. 1 Share this post Link to post Share on other sites
Wooders28 4723 Posted August 30, 2021 Nothing that's competitive on road, is very good for off road tbh. You may be better ,getting a dedicated on road, with a radio with multi model memory, then looking out for a cheapish 2nd hand off road. 1 Share this post Link to post Share on other sites
TurnipJF 9192 Posted August 30, 2021 On 8/29/2021 at 4:31 PM, museguy said: Hi All, I would like to purchase my first RC car, I would like to spend a total of around $300 (car and controller) for a car capable of starting to race on smooth surfaces and playing off-road. I am from the USA living in Mexico City during COVID-19. What do you think of the TT-02 for a first build ? Is the TT-02 better for a first build than the; FF-03 - Front Wheel Drive M-05 - Front Wheel Drive FF-03 - Front Wheel Drive M-03 - Front Wheel Drive It may not seem like it, but you appear to be asking quite a lot from the car. Cars that are ideal as first builds are typically quite simple and straightforward, which means that they are typically not the most advanced racing machines out there. And as others have already stated, a car optimised for off-road is quite different to one optimized for on-road and vice versa. Having one car that is both a simple introduction to building, an effective race machine, and capable of good performance on and off-road is asking quite a lot. The TT-02 is an excellent introduction to building, being pretty straightforward in stock form, and can be a great introduction to racing if raced against cars of similar capabilities in a beginner class or plastic chassis class. However if everybody else is racing high-end carbon chassis cars, it may be quite frustrating. It is also a fair rally car, but not typically able to compete against dedicated rally cars such as the xv-01 for example. And if you are considering serious off-road conditions, you might be better off with a buggy or truck. Comparing it to your other options, in terms of simplicity, it is similar to an M-03, just with more parts. The M-05 is a slightly higher end car, albeit front wheel drive, and the FF-03 is starting to head towards competitive club racer territory, with a lot more adjustability, small parts, and associated build complications. 1 Share this post Link to post Share on other sites
BelknapCrater 179 Posted August 30, 2021 On 8/29/2021 at 8:31 AM, museguy said: Hi All, I would like to purchase my first RC car, I would like to spend a total of around $300 (car and controller) for a car capable of starting to race on smooth surfaces and playing off-road. I am from the USA living in Mexico City during COVID-19. What do you think of the TT-02 for a first build ? Is the TT-02 better for a first build than the; FF-03 - Front Wheel Drive M-05 - Front Wheel Drive FF-03 - Front Wheel Drive M-03 - Front Wheel Drive I am from the USA living in Mexico during COVID-19, suggestions for vendors that ship to Mexico City ? Thank you ! An option (I welcome other suggestions): Flysky FS-GT5 $70 Battery and a charger $40 Steering Servo $25 Subaru Impreza 99 Mone Carlo TT-02 $170 TOTAL $305 If you can dispense with the on-road requirement, an Arrma Senton mega is turn-key, albeit slow. Stretch your budget to $350 and you could get into the BLX with a decent sized lipo. Edit: Senton is RTR, no build option, so no fun 1 Share this post Link to post Share on other sites
Willy iine 18806 Posted August 30, 2021 @museguy I think the TT02 is fine for on and some off road (gravel) driving if your decide on that rally car. One thing I would add is a stronger steering servo saver, however it might not be a direct drop-in so if you'd like, study that option for down the road. It will help recenter the servo for your car to track straight after a turn. Good luck with your choice. 1 Share this post Link to post Share on other sites
museguy 39 Posted August 30, 2021 Hi All, Thank you for the excellent guidance. Maybe I am thinking backward, but since I am in Mexico, I am limited to shipping. I cannot find a local RC Hobby Store. Thinking to buy the Flysky FS-GT5 today. I contacted Tower Hobbies as you suggested and they do not ship to Mexico, I also contacted Horizon Hobby and they do not ship to Mexico. Thank you Share this post Link to post Share on other sites
museguy 39 Posted August 30, 2021 23 hours ago, alvinlwh said: I noticed you did not include ball bearings in your option list, I think that should be essential, not an option. As for who ships to Mexico, the usual suspects from Japan do, like Plaza Japan or Hobby Search are the 2 that I use. Factor in maybe another USD 50 for shopping, best order all you need/can at once to minimise this. (don't make the mistake like me forgetting something and placing another order a few days later!) Dear @alvinlwh Thank you for the suggestion. I looked and Hobby Search does have several TT-02 cars in stock at 14,000 yen or $127 usd, I contacted them about shipping costs 1998 Ford Escort Custom (TT-02 Chassis) Subaru Impreza Monte Carlo `99 (TT-02 Chassis) RCC Lancia Delta HF Integrale (TT-02) (12,160 yen or $110 usd) Dual Ridge (TT-02B Chassis) (RC Model) (10,830 yen or 98 usd) Nismo R34 GT-R Z-tune (TT-02D Chassis) Drift Spec (15,010 yen or $136 usd) Plasma Edge II (TT-02B Chassis) (10,830 or 98 usd) I need to research the differences between the TT-02, the TT-02B and the TT-02D. As of the moment the Subaru Impreza Monte Carlo `99 (TT-02 Chassis) looks like a good option. Cheers Share this post Link to post Share on other sites
museguy 39 Posted August 30, 2021 23 hours ago, alvinlwh said: I noticed you did not include ball bearings in your option list, I think that should be essential, not an option. As for who ships to Mexico, the usual suspects from Japan do, like Plaza Japan or Hobby Search are the 2 that I use. Factor in maybe another USD 50 for shopping, best order all you need/can at once to minimise this. (don't make the mistake like me forgetting something and placing another order a few days later!) Dear @alvinlwh Which ball bearing do you recomend ? Servo Recommendation ? Battery and Charger Recommendation ? Thank you ! Very much appreciated ! Cheers Share this post Link to post Share on other sites
museguy 39 Posted August 30, 2021 2 hours ago, Willy iine said: @museguy I think the TT02 is fine for on and some off road (gravel) driving if your decide on that rally car. One thing I would add is a stronger steering servo saver, however it might not be a direct drop-in so if you'd like, study that option for down the road. It will help recenter the servo for your car to track straight after a turn. Good luck with your choice. Dear @Willy iine Thank you for the recommendation ! Would you please offer suggestions for a servo and a servo saver for the Subaru Impreza Monte Carlo `99 (TT-02 Chassis) Thank you ! Cheers Share this post Link to post Share on other sites
Frog Jumper 3662 Posted August 30, 2021 Is this place close to you??? https://roboticarc.com/ 1 Share this post Link to post Share on other sites
alvinlwh 5895 Posted August 30, 2021 1 minute ago, museguy said: Dear @alvinlwh Thank you for the suggestion. I looked and Hobby Search does have several TT-02 cars in stock at 14,000 yen or $127 usd, I contacted them about shipping costs I need to research the differences between the TT-02, the TT-02B and the TT-02D. As of the moment the Subaru Impreza Monte Carlo `99 (TT-02 Chassis) looks like a good option. There is no need to contact them, just add to your basket, and click check out. You will get all the shipping options then. However, going back to what I said, look at the upgrades and order them at once if you can, as this cuts down on shipping costs. THIS IS STRICTLY PERSONAL, I prefer to install all upgrades at once during the first build as I had experience of a TT01 chassis bursting at the screw holes. This can be prevented if you are careful (plenty of guides on how to screw properly) but I have the phobia if I constantly screw and unscrew the parts. Now, while many will advise you to go local, I do that for the base car myself, but hop ups costs 3x more in the UK than directly from Japan, even if import tax and shipping is taken into account. So if you can get the base car locally, do it as the shipping of a big RC box from Japan is going to cost you, £22 for me when I ordered a small SU-01 car, as they will automatically "kick it" into the higher shipping method. But I had to order from Japan as it is available no where else. I noticed that most of your choices are generally based on real world cars, is that your preference? I am the same here as I do not usually liken buggies. The only buggy I have is the Aero Avante on the SU-01 chassis, and it is effectively a toy grade RC car for a 5yo girl. The TT-02B are all buggies I believe. So if you prefer real world based cars, one option is the M-05Ra (FF) but the only shell I had seen so far at the moment is the 2CV. YMMV at your part of the world although you can get aftermarket body shells. Alternatively, you can get a TT-02 (4WD) and adjust it to the higher position and slap some rally tyres on to give you some off road ability. I hacked a TT-01 into rally specs and that really messed up the handling, but great fun as a basher. Not recommended unless you had some modeling experience AND you know what you will be getting as it is a non reversible operation on the TT01. 2 Share this post Link to post Share on other sites
museguy 39 Posted August 30, 2021 8 hours ago, TurnipJF said: The '02 can be built with high (rally) or standard (on-road) ground clearance with no hacking required. The manual gives clear beginner-friendly instructions on how to do so. Thank you @TurnipJF ! Am I correct in thinking that I could use the Subaru Impreza Monte Carlo `99 (TT-02 Chassis) for entry level racing with a change of tires and the standard (on-road) setting and then change to the high (rally) for rough surfaces ? Cheers ! Share this post Link to post Share on other sites
alvinlwh 5895 Posted August 30, 2021 5 minutes ago, museguy said: Dear @alvinlwh Which ball bearing do you recomend ? Servo Recommendation ? Battery and Charger Recommendation ? Thank you ! Very much appreciated ! Cheers Bearings are pretty standard. You can usually order ready made packs. There are some difference with trust bearings which I do not know about and will probably not matter for a beginner or a starter chassis anyway. Same for servo, there are high speed high torque metal geared servos that cost in the hundred, but I had no problem with a spare decade old servo with a recent build without a problem. Just look local, cheapest is fine in my experience. They don't cost that much in the big picture anyway, so if the cheapest don't work out, rip it out and buy the next cheapest is the way I roll. Batteries are considered dangerous goods and could be difficult to ship internationally, so look local. Your only question is NiMHs or lipos, and the answer is what is available locally. 1 Share this post Link to post Share on other sites
alvinlwh 5895 Posted August 30, 2021 1 hour ago, museguy said: I contacted Tower Hobbies as you suggested and they do not ship to Mexico, I also contacted Horizon Hobby and they do not ship to Mexico. For that Flysky, try aliexpress, but be aware of the long delivery times. I know the pain of shipping as it is almost impossible for me to get dangerous goods like lipos and spray paints delivered to me. 1 Share this post Link to post Share on other sites
BelknapCrater 179 Posted August 30, 2021 @museguy the Fast Eddy bearing kits are ready-made and model specific. Usually 15-20 usd. As far as servos and radios, look into http://hobbyking.com. They sell and shop internationally, and have several inexpensive servo and radio options. 1 Share this post Link to post Share on other sites
Willy iine 18806 Posted August 30, 2021 49 minutes ago, museguy said: Dear @Willy iine Thank you for the recommendation ! Would you please offer suggestions for a servo and a servo saver for the Subaru Impreza Monte Carlo `99 (TT-02 Chassis) Thank you ! Cheers You're very welcome. I have been using a very generic no-brand servo sold on Amazon which is in a voilet/reddish color. They go for $15 each and you should be able to find it if you search "digital 20kg servo". This is what it looks like.. I usually buy in a 4 pack for less than $50. While cheap, they work very well and most of my jeeps and trucks run them. As for the servo saver I usually use Tamiya's #51000. But try your factory servo saver first because the horn shape is different on the 51000 and will require some modification to make it fit. 2 Share this post Link to post Share on other sites
Dakratfink 967 Posted August 30, 2021 15 minutes ago, Willy iine said: I have been using a very generic no-brand servo sold on Amazon which is in a voilet/reddish color. They go for $15 each and you should be able to find it if you search "digital 20kg servo". This is what it looks like.. I usually buy in a 4 pack for less than $50. While cheap, they work very well and most of my jeeps and trucks run them. I run one of these in a “generic” SCX.10 “clone” crawler. I run it without a saver and have had no problems with it yet. I’m probably going to invest in a 4 pack soon just for future projects 2 Share this post Link to post Share on other sites
