I have a vintage Wild One that needs to be painted.
If I remember, my Terra Scorcher also had a molded figure from polycarbonate shell and I may have used an acrylic pen for it which I painted on the outside... I guess I have to look at it again and see if it held fine... however this time, I do plan on using a brush and actual acrylic paint...
I think if the acrylic is thick enough it can work.  And since the driver is inside a cage, no issue with direct hit unless you drove your car into a bush.. :blink:
I actually painted a polycarbonate driver figure by starting with a coat of PS-55 Flat Clear, and then painting on the acrylics. The PS-55 keys the surface of the material, which allows the other paint to adhere to it better.
More recently, on a Terra Scorcher, I used PS-5 Black on the figure (which was part of a chassis cover, painted on the outside) and then painted regular acrylics on top. Granted, the driver figure is not really a load-bearing member, but the result is still free of flaking or chips!
Thanks. I will try to paint my Wild One tomorrow and see how it goes. Ive decided to just use a regular acrylic paint without any type of prepainting whatsoever… i kust need to make sure surface is clean before i start brushing the paint. I recognize that it will take a few coats to fully cover the polycarb shell.
On 10/17/2021 at 9:58 PM, alvinlwh said:
When you say "regular" acrylic paint, what do you mean? Tamiya X/XF? Mr hobby C? Both these (and a hand full of others) are not true acrylics and should not be used.
just a set of acrylic paint i have in my classroom; no name brand... it looks like it is adhering ok. I just had to put multple coats and let it air dry. I applied the paint on the underside of the shell where it will be less prone to surface scratching.. I'l' post a photo when I'm done.
Why is that?
Never had an issue with Tamiya X/XF paints for polycarbonate cockpits/drivers.
