Lunchy 27 Posted September 30, 2021 Hello everyone. I have a lunch box with a Futaba s3004 servo with it. I just took it out, noticed the wheels wouldn't turn. Looked at it and the screw that goes into the servo was missing. Only the second time I brought it out for a run. I think the screw came with the lunch box kit???.. maybe not. I guess my question is, is there a place I can get a few replacement screws? Thanks! Share this post Link to post Share on other sites
Juggular 4964 Posted September 30, 2021 It's one of these 4 screws. If you take out the servo, you can see the thread. If not, try one by one. Don't force it. Thread locker could prevent the screw from coming out. You can even use school glue. Share this post Link to post Share on other sites
sosidge 624 Posted September 30, 2021 Futaba plastic gear servos (like the S3004) use an M2.6 tapping screw. You might have got some extras with the servo anyway. Share this post Link to post Share on other sites
TurnipJF 9192 Posted September 30, 2021 Securing the screw with a smear of superglue on the threads is a good idea. Avoid threadlock as it attacks the plastic. 1 1 Share this post Link to post Share on other sites
Lunchy 27 Posted October 1, 2021 I wonder if these would work? https://futabausa.com/product/fsh-51/ They are from Futaba... so maybe. Let me know what you guys think. Thanks again! Share this post Link to post Share on other sites
alvinlwh 5895 Posted October 1, 2021 27 minutes ago, Lunchy said: I wonder if these would work? https://futabausa.com/product/fsh-51/ They are from Futaba... so maybe. Let me know what you guys think. Thanks again! That is the same as BA7 from Tamiya. Share this post Link to post Share on other sites
Willy iine 18806 Posted October 1, 2021 @Lunchy Are you using the factory servo saver horn? In this case you may have lost the plastic spacer too (P1) that goes under the screw and into the servo saver horn. The horn will not operate properly without that spacer. It's possible the screw you used was too short too.. The screw in the CW01's manual use BB2 below or 3x12mm tapping screw for servos that use self tapping screws. Share this post Link to post Share on other sites
alvinlwh 5895 Posted October 1, 2021 30 minutes ago, Willy iine said: @Lunchy Are you using the factory servo saver horn? In this case you may have lost the plastic spacer too (P1) that goes under the screw and into the servo saver horn. I always forget that part when building and then wondering why my horn falls apart! Share this post Link to post Share on other sites
Lunchy 27 Posted October 1, 2021 Good call - Looks like the spacer is not there either. Crap!!! Any ideas on the best way to get these parts? Do I need to buy a new chassis or something... yikes! Share this post Link to post Share on other sites
Frog Jumper 3662 Posted October 1, 2021 2 minutes ago, Lunchy said: Any ideas on the best way to get these parts? Do I need to buy a new chassis or something... yikes! Tamiya 50204. https://www.tamiyausa.com/shop/spare-parts/rc-servo-saver-set/ Terry Share this post Link to post Share on other sites
Lunchy 27 Posted October 1, 2021 Awesome... thanks. I do a lot shopping here... looks like the same thing. https://www.amainhobbies.com/tamiya-servo-saver-set-tam50204/p-quaxqswahm2xactz?gclid=CjwKCAjw49qKBhAoEiwAHQVTo5oMlLOitfcC3L82e0WT2sfbwEZZ3GqFi5W2hBkjk1OC5glPZo9jrxoCJWAQAvD_BwE Thanks! 1 Share this post Link to post Share on other sites
Dakratfink 967 Posted October 1, 2021 5 hours ago, Lunchy said: Awesome... thanks. I do a lot shopping here... looks like the same thing. https://www.amainhobbies.com/tamiya-servo-saver-set-tam50204/p-quaxqswahm2xactz?gclid=CjwKCAjw49qKBhAoEiwAHQVTo5oMlLOitfcC3L82e0WT2sfbwEZZ3GqFi5W2hBkjk1OC5glPZo9jrxoCJWAQAvD_BwE Thanks! That looks like the correct part tree. Share this post Link to post Share on other sites
alvinlwh 5895 Posted October 2, 2021 10 hours ago, Lunchy said: Awesome... thanks. I do a lot shopping here... looks like the same thing. https://www.amainhobbies.com/tamiya-servo-saver-set-tam50204/p-quaxqswahm2xactz?gclid=CjwKCAjw49qKBhAoEiwAHQVTo5oMlLOitfcC3L82e0WT2sfbwEZZ3GqFi5W2hBkjk1OC5glPZo9jrxoCJWAQAvD_BwE Thanks! While you are at it, why not get a Tamiya 51000 instead? It is a better replacement. Share this post Link to post Share on other sites
Willy iine 18806 Posted October 2, 2021 23 minutes ago, alvinlwh said: While you are at it, why not get a Tamiya 51000 instead? It is a better replacement. It is most definitely, but S3004's do not have the level of torque (like 1.6kg at 6V) that can justify the extra stiffness. May end up breaking the servo with a big enough hit on the front wheels. Luckily CW01's have a light front end so the S3004 and factory servo saver should be adequate. Share this post Link to post Share on other sites
nel33 870 Posted October 2, 2021 There is also a stronger plastic servo saver horn that doesn't require that tiny plastic washer. Got it off eBay, 300% stronger plastic servo saver. Put that on the lunch box, it's indeed very hard, it's also harder to screw the screw into it. I opted to drill tap m3x0.5 tap tool and add m3 luck nut. My lunchbox doesn't get much run time but I did buy an aluminum horn and steering set in case the stronger plastic horn breaks. Had 2 strong plastic ones, one broke when I forced too hard with machine threads so drill/tap tool won. I could never figure out how you are supposed to agree that into the horn with machine tread screws. Share this post Link to post Share on other sites
