Sign in to follow this
Jonathon Gillham
Wanted 44mm universal
I need a pair of universals which fit the TA07Pro. The kit ones are 44mm, but I don't mind what brand as long as they work. Everywhere is out of stock atm and DCJs for USD60 plus shipping doesn't really fit the bill for a budget parts build.
Does anyone have anything lying around?
Are you still looking? Looks like they're back in stock at Plaza...or, alternatively....
I recently bought a TA07Pro from a fellow TC member, and it came with DCJs up front and UJs at the back. It also came with the original universals as spares which I probably won't be using
They are built but if they've been used at all it's very lightly, there are a couple of light bearing marks on the axles and a very light amount of grease in the joint. They've got a pair of 1050 bearings attached and there's a couple of spare pins in there too
spacer.png.
Shipping from the UK to NZ is £4.30 untracked or £9.75 tracked. Let me know if you're interested and we can work out a price for the parts.
I recently bought a TA07Pro from a fellow TC member, and it came with DCJs up front and UJs at the back. It also came with a complete spare set of DCJs which I probably won't be using
They are built but if they've been used at all it's very lightly, there are a couple of light bearing marks on the axles and a very light amount of grease in the joint. They've got a pair of bearings attached and there's a couple of spare pins in there too
spacer.png.
Those are the original kit ones and would be ideal. The DCJs have a longer joint and 2 of those rings holding them together. I'll PM you
