Hi, do you know the Delta wheels offset please?
I must print wider arms for the TA02 to eliminate the fenders gap that I don't like but currently I measured the gap with HPI star wheels that have more offset, I believe.
Can you help me?
Max
Incidentally, I have a set of Delta wheels at my 7 O'Clock direction.  And a plastic caliper at 1 O'Clock.  What are the chances that both were within arms reach?!  (I'm the guy who couldn't find the metal caliper for 4 years! hence the plastic one...)
The width of the wheel is about 26mm.  So if the offset were zero, that'd be 13mm from inside wall or outside wall.
I didn't know where I should measure it from, so I did it from the deepest part first.
Measuring the deepest part to the inside wall, my caliper showed 18.8mm.  So that's close to 6mm (5.8mm) from the centerline.
I also measured from the yellow arrow below. (It measured 13.9mm from the inside wall to the yellow arrow. If you subtract 13mm centerline, that's 0.9mm positive offset.)
Measuring from outside,
...it showed 4.8mm.
I hope that was useful.
5 hours ago, whahooo said:
I also have to widen the Stance in my TL01.
Is there another way to widen the Wheels for about 2 - 3 mm?
If the matter is 2 mm you can add a spacer behind the wheels.
If you need 5 or 6 mm like me no way with the spacer.
Max
2 hours ago, svenb said:
50808 axles should give approximately 5-6mm each side.
Used with wider hex's
They would be a very good option if the was CVDs.
Max
Posted (edited)
Max
I believe there is a CVD option for a different chassis that fits,cc01??
TB01 long universal shaft set fits, I used them on a tl01.
Not cc01🙄
Edited by svenb
Do you remember the lenght of the TA02 shafts?
Probably I'll need some 5 mm longer.
Max
Max
Front or rear?
5 minutes ago, svenb said:
No you need the cc01 universal shaft set , possibly with longer drive shafts
Yes, I believe that they doesn't exist.
TB-01 could be useful for the rear end.
Max
Max
I've had a good route through my stock and I can't find a way to lengthen the front ta02 axles as cvd's only using the ta03 long axle hop up.
Unless you use the 50808 and put bearings in bearings!?
On 11/2/2021 at 10:35 PM, kontemax said:
Not sure if the TB-01 shafts will work on front end of the TA02.
MAx
You could use TA01 (or similar) knuckles and axles at front - that should give you about 6mm per side - TA02W has been done that way. It'd also allow you to use modern CVDs or DCJs, as TA01 has same wheel axle length as M-chassis
