Some (and most have) 8 of these, they are delivered as 4. Are they made do you can use 4?.
Some says they are not easy to setup and ofc you need them to be just right, how hard is it?.
On ny Top-Force i could feel and see a big improvement after installing the very good Top-Force Hoo-Up damper set, will i see the same difference here you think?
I'm using 8 of these (rear dampers from Kyosho Outlaw Rampage Pro) along with stock Agrios springs.  Not nearly as expensive as the EIGHT Tamiya dual reservoir dampers (of which I have on my Bullhead) and work much better.
1/10 Scale Radio Controlled Electric Powered 2WD Truck 2RSA SERIES Outlaw  Rampage PRO 34362 - KYOSHO RC
Tried to look for them but could not find them, do you have the product name pretty please?
I saw someone just use 4 of the tamiya reservoir shocks along with i believe a black stock one years ago. I dont remember what they said the reason or how it worked. I have 8 on mine with associated springs and i believe 25 w oil. I used the associated spring because of a build i saw on clodtalk from around 2017 and they said the stock tamiya shocks were i believe to soft. I need to change the oil out and go a lighter weight.  They look great but i do not see much of a difference than the stock set.  That again  may have alot to do with my oil weight.
I know they are probably worse than stock but saw simillar oil shocks banggood that where cheap and prized wrong (same prize for 4 as for 2 pieces). There where 1 review from an Italian guy that gave them 5 stars and seem to know a bit about RC, wrote they where all Metal.
Got 8 pieces for 260 kr (around 25 GBP), if im very lucky they are Ok:spacer.png
